Desde : 05/11/2013
Idade : 26
em Ter 07 Jan 2014, 03:42
Andei vendo muitas Source e vi que e totalmente diferente do modo que eu faço um exemplo
um script não compilado mod Peds com medo de armas
code:
{$CLEO}
wait 1000
const
  Getted___Ped = 0@
var
  0@ : int
  1@ : float
  2@ : float
  3@ : float
  $PLAYER_ACTOR : int
  25@ : int
  if 0256:   player 0 defined
  jf continue
  12@ = false
  0470: 9@ = actor $PLAYER_ACTOR current_weapon
     9@ > 15
     40 > 9@
     12@ = true
  0A8D: 29@ = read_memory 0xB74490 size 4 virtual_protect 0
  29@ += 0x4
  for 30@ = 0 to 27904 step 0x100
     0A8D: Getted___Ped = read_memory 29@ size 1 virtual_protect 0
     000A: 29@ += 0x1
        0029: Getted___Ped >= 0x00
        001B: 0x80 > Getted___Ped
        005A: Getted___Ped += 30@
        089F: get_actor Getted___Ped pedtype_to 7@
        if 7@ == 6
           25@ = Getted___Ped
        if 8118:   not actor Getted___Ped dead
        jf continue
        if $PLAYER_ACTOR <> 0@
        jf continue
        0AAA: 14@ = thread 'COPCAR' pointer
           14@ == 0 // checks if the player is not on a vigilante mission
           12@ == true
           if 09ED:   actor Getted___Ped is_within_field_of_view_actor $3
           jf continue
           if 00DF:   actor $PLAYER_ACTOR driving
              0811: 20@ = actor $PLAYER_ACTOR car
              02E3: 20@ = car 20@ speed
              if 20@ < 10.0
              jf continue
           gosub @Stuffs
        gosub @OtherCopAndPedFixes
hex
  "Mod by Fabio - http://gtamodvicio.blogspot.com - http://mixmods.blogspot.com - http://brmodstudio.forumeiros.com"
:OtherCopAndPedFixes
  7@ > 6
  7@ < 18
  0470: 9@ = actor Getted___Ped current_weapon
     9@ > 15
     40 > 9@
     if 056D:   actor 25@ defined
     0AA1: return_if_false
     if 09ED:   actor 25@ is_within_field_of_view_actor Getted___Ped
     if 8248:  not model #desert_eagle available
        0247: load_model #desert_eagle
        038B: load_requested_models
     01B2: give_actor 25@ weapon 24 ammo 9999
     01B9: set_actor 25@ armed_weapon_to 24
     05E2: AS_actor 25@ kill_actor Getted___Ped
return
:Stuffs
if 7@ == 6
  if 810F:   not player 0 wanted_level > 1
     01C0: 8@ = player 0 wanted_level
     8@ += 1
     010D: set_player 0 wanted_level_to 8@
  05E2: AS_actor Getted___Ped kill_actor $3
  return
1@ = random(50.0, 250.0)
2@ = random(00.0, 250.0)
if 00DF:   actor Getted___Ped driving
  0811: 20@ = actor Getted___Ped car
  00A7: car 20@ drive_to 4@ 5@ 6@
  00AF: set_car 20@ driver_behaviour_to 8
  return
  7@ > 6
  7@ <> 8
  7@ < 18
  return
04C4: store_coords_to 4@ 5@ 6@ from_actor Getted___Ped with_offset 1@ 2@ 0.0
05DA: AS_actor Getted___Ped run_away_in_panic_from 4@ 5@ 6@ away_radius 100.0 timelimit 15000
return
agora um script meu não compilado
code 2:
0000: NOP
:Noname_2
0001: wait 0 ms
00D6: if
0AB0:   key_pressed 77
004D: jump_if_false @Noname_2
0001: wait 100 ms
00D6: if
010A:   player $PLAYER_CHAR money > 200
004D: jump_if_false @Noname_44
0006: 1@ = 200
0006: 2@ = 500
0006: 3@ = 100
:Noname_1
0001: wait 0 ms
01B4: set_player $PLAYER_CHAR can_move 0
08D4: 14@ = create_panel_with_title 'AMMUN' position 29.0 170.0 width 180.0 columns 1 interactive 1 background 1 alignment 0  // Ammu-Nation
08DB: set_panel 14@ column 0 header 'WEAPON' data 'GUN1' 'GUN2' 'GUN3' 'GUN4' 'GUN5' 'GUN6' 'GUN7' 'GUN8' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY'  // Weapon // Monday // Wednesday // Thursday // Friday // Saturday
08EE: set_panel 14@ column 1 row 0 text_1number GXT 'DOLLAR' number 1@  // $~1~
08EE: set_panel 14@ column 1 row 1 text_1number GXT 'DOLLAR' number 2@  // $~1~
08EE: set_panel 14@ column 1 row 2 text_1number GXT 'DOLLAR' number 2@  // $~1~
08EE: set_panel 14@ column 1 row 3 text_1number GXT 'DOLLAR' number 2@  // $~1~
08EE: set_panel 14@ column 1 row 4 text_1number GXT 'DOLLAR' number 2@  // $~1~
08EE: set_panel 14@ column 1 row 5 text_1number GXT 'DOLLAR' number 2@  // $~1~
:Noname_3
0001: wait 0 ms
00D6: if
00E1:   player 0 pressed_key 16
08D7: 14@ = panel 14@ active_row
0001: wait 100 ms
0002: jump @Noname_5
:Noname_44
0001: wait 0 ms
0ACA: show_text_box "voce nao tem dinheiro suficiente"
0002: jump @Noname_2
:Noname_4
0001: wait 0 ms
00D6: if
0AB0:   key_pressed 13
004D: jump_if_false @Noname_3
08DA: remove_panel 14@
08DA: remove_panel 17@
01B4: set_player $PLAYER_CHAR can_move 1
:Noname_5
0001: wait 0 ms
0039:   14@ == 0
004D: jump_if_false @Noname_16
0002: jump @Noname_6
:Noname_16
0001: wait 0 ms
14@ == 1
004D: jump_if_false @Noname_27
0002: jump @Noname_17
:Noname_27
0001: wait 0 ms
14@ == 2
004D: jump_if_false @Noname_36
0002: jump @Noname_28
:Noname_36
0001: wait 0 ms
14@ == 3
0002: jump @Noname_37
:Noname_6
0001: wait 0 ms
08D4: 17@ = create_panel_with_title 'AMMUN' position 29.0 170.0 width 180.0 columns 1 interactive 1 background 1 alignment 0  // Ammu-Nation
08DB: set_panel 17@ column 0 header 'PISTOLAS' data 'PISTOL' 'PISTSL' 'DEAGLE' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY'
08EE: set_panel 17@ column 1 row 0 text_1number GXT 'DOLLAR' number 1@  // $~1~
08EE: set_panel 17@ column 1 row 1 text_1number GXT 'DOLLAR' number 1@  // $~1~
08EE: set_panel 17@ column 1 row 2 text_1number GXT 'DOLLAR' number 1@  // $~1~
0002: jump @Noname_8
:Noname_7
0001: wait 0 ms
0ACA: show_text_box "vc esta sem dinheiro"
:Noname_8
0001: wait 0 ms
00D6: if
004D: jump_if_false @Noname_9
08D7: 17@ = panel 17@ active_row
0001: wait 100 ms
0002: jump @Noname_10
:Noname_9
0001: wait 0 ms
00D6: if
004D: jump_if_false @Noname_8
0001: wait 100 ms
:Noname_10
0001: wait 0 ms
0039:   17@ == 0
004D: jump_if_false @Noname_12
010B: 4@ = player $PLAYER_CHAR money
002D:   4@ >= 1@ // (int)
004D: jump_if_false @Noname_7
0062: 0@ -= 1@ // (int)
0109: player $PLAYER_CHAR money += 0@
0247: load_model #COLT45
:Noname_11
0001: wait 0 ms
0248:   model #COLT45 available
004D: jump_if_false @Noname_11
01B2: give_actor $PLAYER_ACTOR weapon 22 ammo 60 // Load the weapon model before using this
0ACA: show_text_box "uma bela arma pra assasinatos furtivos"
:Noname_12
0001: wait 0 ms
17@ == 1
004D: jump_if_false @Noname_14
002D:   4@ >= 2@ // (int)
0062: 0@ -= 2@ // (int)
0247: load_model #SILENCED
:Noname_13
0001: wait 0 ms
0248:   model #SILENCED available
004D: jump_if_false @Noname_13
01B2: give_actor $PLAYER_ACTOR weapon 23 ammo 60 // Load the weapon model before using this
:Noname_14
0001: wait 0 ms
17@ == 2
002D:   4@ >= 3@ // (int)
0062: 0@ -= 3@ // (int)
0247: load_model #DESERT_EAGLE
:Noname_15
0001: wait 0 ms
0248:   model #DESERT_EAGLE available
004D: jump_if_false @Noname_15
01B2: give_actor $PLAYER_ACTOR weapon 24 ammo 60 // Load the weapon model before using th
:Noname_17
0001: wait 0 ms
08DA: remove_panel 19@
08DA: remove_panel 20@
08D4: 18@ = create_panel_with_title 'AMMUN' position 29.0 170.0 width 180.0 columns 1 interactive 1 background 1 alignment 0  // Ammu-Nation
08DB: set_panel 18@ column 0 header 'PISTOLAS' data 'SHOTGN1' 'SHOTGN3' 'SHOTGN1' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY'
08EE: set_panel 18@ column 1 row 0 text_1number GXT 'DOLLAR' number 1@  // $~1~
08EE: set_panel 18@ column 1 row 1 text_1number GXT 'DOLLAR' number 1@  // $~1~
08EE: set_panel 18@ column 1 row 2 text_1number GXT 'DOLLAR' number 1@  // $~1~
:Noname_18
0001: wait 0 ms
00D6: if
004D: jump_if_false @Noname_19
08D7: 18@ = panel 18@ active_row
0001: wait 100 ms
0002: jump @Noname_20
:Noname_22
0001: wait 0 ms
0002: jump @Noname_16
:Noname_19
0001: wait 0 ms
00D6: if
004D: jump_if_false @Noname_18
08DA: remove_panel 18@
0001: wait 100 ms
:Noname_20
0001: wait 0 ms
18@ == 0
004D: jump_if_false @Noname_23
004D: jump_if_false @Noname_22
0247: load_model #CHROMEGUN
:Noname_21
0001: wait 0 ms
0248:   model #CHROMEGUN available
004D: jump_if_false @Noname_21
01B2: give_actor $PLAYER_ACTOR weapon 25 ammo 60 // Load the weapon model before using th
:Noname_23
0001: wait 0 ms
18@ == 1
004D: jump_if_false @Noname_25
0247: load_model #SAWNOFF
:Noname_24
0001: wait 0 ms
0248:   model #SAWNOFF available
004D: jump_if_false @Noname_24
01B2: give_actor $PLAYER_ACTOR weapon 26 ammo 60 // Load the weapon model before using th
:Noname_25
0001: wait 0 ms
18@ == 2
004D: jump_if_false @Noname_17
0247: load_model #SHOTGSPA
:Noname_26
0001: wait 0 ms
0248:   model #SHOTGSPA available
004D: jump_if_false @Noname_26
01B2: give_actor $PLAYER_ACTOR weapon 27 ammo 60 // Load the weapon model before using th
:Noname_28
0001: wait 0 ms
08D4: 19@ = create_panel_with_title 'AMMUN' position 29.0 170.0 width 180.0 columns 1 interactive 1 background 1 alignment 0  // Ammu-Nation
08DB: set_panel 19@ column 0 header 'PISTOLAS' data 'UZI' 'TEC9' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY'
08EE: set_panel 19@ column 1 row 0 text_1number GXT 'DOLLAR' number 1@  // $~1~
08EE: set_panel 19@ column 1 row 1 text_1number GXT 'DOLLAR' number 1@  // $~1~
:Noname_29
0001: wait 0 ms
00D6: if
004D: jump_if_false @Noname_31
08D7: 19@ = panel 19@ active_row
0001: wait 100 ms
0002: jump @Noname_32
:Noname_30
0001: wait 0 ms
0002: jump @Noname_27
:Noname_31
0001: wait 0 ms
00D6: if
004D: jump_if_false @Noname_29
0001: wait 100 ms
:Noname_32
0001: wait 0 ms
19@ == 0
004D: jump_if_false @Noname_34
004D: jump_if_false @Noname_30
0247: load_model #MICRO_UZI
:Noname_33
0001: wait 0 ms
0248:   model #MICRO_UZI available
004D: jump_if_false @Noname_33
01B2: give_actor $PLAYER_ACTOR weapon 28 ammo 60 // Load the weapon model before using th
:Noname_34
0001: wait 0 ms
19@ == 1
004D: jump_if_false @Noname_28
0247: load_model #TEC9
:Noname_35
0001: wait 0 ms
0248:   model #TEC9 available
004D: jump_if_false @Noname_35
01B2: give_actor $PLAYER_ACTOR weapon 32 ammo 60 // Load the weapon model before using th
:Noname_37
0001: wait 0 ms
08D4: 20@ = create_panel_with_title 'AMMUN' position 29.0 170.0 width 180.0 columns 1 interactive 1 background 1 alignment 0  // Ammu-Nation
08DB: set_panel 20@ column 0 header 'GUN4' data 'GUN4' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY' 'DUMMY'
08EE: set_panel 20@ column 1 row 0 text_1number GXT 'DOLLAR' number 1@  // $~1~
:Noname_38
0001: wait 0 ms
00D6: if
004D: jump_if_false @Noname_40
08D7: 20@ = panel 20@ active_row
0001: wait 100 ms
0002: jump @Noname_41
:Noname_39
0001: wait 0 ms
:Noname_40
0001: wait 0 ms
00D6: if
004D: jump_if_false @Noname_38
0001: wait 100 ms
:Noname_41
0001: wait 0 ms
20@ == 0
004D: jump_if_false @Noname_39
0247: load_model #MP5LNG
:Noname_42
0001: wait 100 ms
0248:   model #MP5LNG available
004D: jump_if_false @Noname_42
01B2: give_actor $PLAYER_ACTOR weapon 29 ammo 80 // Load the weapon model before using th
Olhando a primeira script e olhando a minha é que eu fico com duvida se estou fazendo certo ou se estou fazendo errado
em Ter 07 Jan 2014, 10:37
Vc tá fazendo errado só em editar scripts e não tentar criar seus próprios
em Ter 07 Jan 2014, 12:26
Depende do que você chama de errado né
Não acho um script low level "errado", só acho que fica ruim pra ler...
Desde : 05/11/2013
Idade : 26
em Ter 07 Jan 2014, 15:39
nao cara esse script eu fiz do zéro nao peguei um mod pronto e editei
