em Ter 04 Ago 2015, 13:27
Tá com o Silent ASI Loader?
Mod Loader - Topico Oficial - Página 41 226c0ef57f9d7520d171cbadc68b3c56
Mod Loader - Topico Oficial - Página 41 76561198069372249
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 14:47
Sim claro!Tenho 3 asi loaders,no print que eu mandei eu to usando o da mix mods na pasta do gta sa.
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 16:05
Todos os detalhes do meu erro estão nesses prints ai. http://prntscr.com/80twms - http://prntscr.com/80tx24 - http://prntscr.com/80txy7 Link do mod:http://www.gamemodding.net/en/gta-san-andreas/gta-sa-cleo-scripts/48754-first-person-mod-v30.html ah e o ultimo log:
[code]========================== Mod Loader 0.2.4 ==========================
Game version: GTA SA 1.0 US
Parsing command line
Loaded fallback menu fxt
Looking for plugins...
Reading plugins.ini
Plugin module "gta3\std.asi.dll" loaded as gta3.std.asi Feb 12 2015 22:09:09 by LINK/2012
CLEO library version 4030000 found at "CLEO.asi"
Plugin module "gta3\std.bank.dll" loaded as gta3.std.bank Feb 12 2015 22:08:44 by LINK/2012
Plugin module "gta3\std.data.dll" loaded as gta3.std.data Feb 12 2015 22:09:14 by LINK/2012
Plugin module "gta3\std.fx.dll" loaded as gta3.std.fx Feb 12 2015 22:08:29 by LINK/2012
Plugin module "gta3\std.movies.dll" loaded as gta3.std.movies Feb 12 2015 22:08:15 by LINK/2012
Plugin module "gta3\std.scm.dll" loaded as gta3.std.scm Feb 12 2015 22:08:17 by LINK/2012
Plugin module "gta3\std.sprites.dll" loaded as gta3.std.sprites Feb 12 2015 22:08:20 by LINK/2012
Plugin module "gta3\std.stream.dll" loaded as gta3.std.stream Feb 12 2015 22:08:53 by LINK/2012
Plugin module "gta3\std.text.dll" loaded as gta3.std.text Feb 12 2015 22:08:37 by LINK/2012
Plugin module "gta3\std.tracks.dll" loaded as gta3.std.tracks Feb 12 2015 22:08:41 by LINK/2012
Scanning files at "modloader\fps\"...
No handler or callme for file "FirstPerson.cfg"
No handler or callme for file "FirstPerson.sp"
Found file [0x00000204A738B180] "FirstPerson.txd" with handler "gta3.std.stream"
No handler or callme for file "fonts\fp_font.dat"
Found file [0x00000204588456FF] "fonts\fp_font.txd" with handler "gta3.std.stream"
No handler or callme for file "GUI.fp"
Found file [0x0000000113000BEC] "Hooks.asi" with handler "gta3.std.asi"
No handler or callme for file "msvcr100d.dll"
Updating state for "modloader\fps\"...
Installing file "modloader\fps\firstperson.txd"
Installing file "modloader\fps\fonts\fp_font.txd"
Installing file "modloader\fps\hooks.asi"
[ASI] Failed to load module "hooks.asi"; errcode: 0x45A
Failed to Install file "modloader\fps\hooks.asi"
Mod Loader has started up!
Loading default plants surface properties "PLANTS.DAT"
Loading default anim association "DATA\ANIMGRP.DAT"
Loading default stream config "stream.ini"
Loading default fighting data "DATA\melee.dat"
Preloading level file "DATA\DEFAULT.DAT"
Preloading level file "DATA\GTA.DAT"
Loading default level file "DATA\GTA.DAT"
Loading preloaded level entries...
Opening file for streaming "data\paths\carrec.img"
Opening file for streaming "data\script\script.img"
Opening file for streaming "models\cutscene.img"
Loading default object types "data\default.ide"
Loading default object types "data\vehicles.ide"
Loading default object types "data\peds.ide"
Loading default object types "data\maps\generic\vegepart.ide"
Loading default object types "data\maps\generic\barriers.ide"
Loading default object types "data\maps\generic\dynamic.ide"
Loading default object types "data\maps\generic\dynamic2.ide"
Loading default object types "data\maps\generic\multiobj.ide"
Loading default object types "data\maps\generic\procobj.ide"
Loading default object types "data\maps\la\lan.ide"
Loading default object types "data\maps\la\lan2.ide"
Loading default object types "data\maps\la\las.ide"
Loading default object types "data\maps\la\las2.ide"
Loading default object types "data\maps\la\lae.ide"
Loading default object types "data\maps\la\lae2.ide"
Loading default object types "data\maps\la\law2.ide"
Loading default object types "data\maps\la\law.ide"
Loading default object types "data\maps\la\lawn.ide"
Loading default object types "data\maps\la\lahills.ide"
Loading default object types "data\maps\la\laxref.ide"
Loading default object types "data\maps\sf\sfn.ide"
Loading default object types "data\maps\sf\sfs.ide"
Loading default object types "data\maps\sf\sfse.ide"
Loading default object types "data\maps\sf\sfe.ide"
Loading default object types "data\maps\sf\sfw.ide"
Loading default object types "data\maps\sf\sfxref.ide"
Loading default object types "data\maps\vegas\vegasn.ide"
Loading default object types "data\maps\vegas\vegass.ide"
Loading default object types "data\maps\vegas\vegase.ide"
Loading default object types "data\maps\vegas\vegasw.ide"
Loading default object types "data\maps\vegas\vegaxref.ide"
Loading default object types "data\maps\country\countryn.ide"
Loading default object types "data\maps\country\countn2.ide"
Loading default object types "data\maps\country\countrys.ide"
Loading default object types "data\maps\country\countrye.ide"
Loading default object types "data\maps\country\countryw.ide"
Loading default object types "data\maps\country\counxref.ide"
Loading default object types "data\maps\interior\int_la.ide"
Loading default object types "data\maps\interior\int_sf.ide"
Loading default object types "data\maps\interior\int_veg.ide"
Loading default object types "data\maps\interior\int_cont.ide"
Loading default object types "data\maps\leveldes\levelmap.ide"
Loading default object types "data\maps\leveldes\levelxre.ide"
Loading default object types "data\maps\interior\gen_int1.ide"
Loading default object types "data\maps\interior\gen_int2.ide"
Loading default object types "data\maps\interior\gen_intb.ide"
Loading default object types "data\maps\interior\gen_int3.ide"
Loading default object types "data\maps\interior\gen_int4.ide"
Loading default object types "data\maps\interior\gen_int5.ide"
Loading default object types "data\maps\interior\savehous.ide"
Loading default object types "data\maps\interior\stadint.ide"
Loading default object types "data\maps\leveldes\seabed.ide"
Loading default object types "data\maps\interior\props.ide"
Loading default object types "data\maps\interior\props2.ide"
Loading default object types "data\maps\interior\propext.ide"
Loading default object types "data\maps\veh_mods\veh_mods.ide"
Loading default object types "data\txdcut.ide"
Loading default vehicle colours "DATA\CARCOLS.DAT"
Loading default vehicle upgrades "DATA\CARMODS.DAT"
Initializing the streaming...
Importing model file for index 23601 at "modloader\fps\firstperson.txd"
Importing model file for index 23602 at "modloader\fps\fonts\fp_font.txd"
Loading default scene "data\map.zon"
Loading default scene "data\info.zon"
Loading default scene "data\maps\la\lan.ipl"
Loading default scene "data\maps\la\lan2.ipl"
Loading default scene "data\maps\la\las.ipl"
Loading default scene "data\maps\la\las2.ipl"
Loading default scene "data\maps\la\lae.ipl"
Loading default scene "data\maps\la\lae2.ipl"
Loading default scene "data\maps\la\law.ipl"
Loading default scene "data\maps\la\lawn.ipl"
Loading default scene "data\maps\la\law2.ipl"
Loading default scene "data\maps\la\lahills.ipl"
Loading default scene "data\maps\sf\sfn.ipl"
Loading default scene "data\maps\sf\sfs.ipl"
Loading default scene "data\maps\sf\sfse.ipl"
Loading default scene "data\maps\sf\sfe.ipl"
Loading default scene "data\maps\sf\sfw.ipl"
Loading default scene "data\maps\vegas\vegasn.ipl"
Loading default scene "data\maps\vegas\vegass.ipl"
Loading default scene "data\maps\vegas\vegase.ipl"
Loading default scene "data\maps\vegas\vegasw.ipl"
Loading default scene "data\maps\country\countryn.ipl"
Loading default scene "data\maps\country\countn2.ipl"
Loading default scene "data\maps\country\countrys.ipl"
Loading default scene "data\maps\country\countrye.ipl"
Loading default scene "data\maps\country\countryw.ipl"
Loading default scene "data\maps\interior\int_la.ipl"
Loading default scene "data\maps\interior\int_sf.ipl"
Loading default scene "data\maps\interior\int_veg.ipl"
Loading default scene "data\maps\interior\int_cont.ipl"
Loading default scene "data\maps\interior\gen_int1.ipl"
Loading default scene "data\maps\interior\gen_int2.ipl"
Loading default scene "data\maps\interior\gen_intb.ipl"
Loading default scene "data\maps\interior\gen_int3.ipl"
Loading default scene "data\maps\interior\gen_int4.ipl"
Loading default scene "data\maps\interior\gen_int5.ipl"
Loading default scene "data\maps\interior\stadint.ipl"
Loading default scene "data\maps\interior\savehous.ipl"
Loading default scene "data\maps\leveldes\levelmap.ipl"
Loading default scene "data\maps\leveldes\seabed.ipl"
Loading default scene "data\maps\paths.ipl"
Loading default scene "data\maps\paths2.ipl"
Loading default scene "data\maps\paths3.ipl"
Loading default scene "data\maps\paths4.ipl"
Loading default scene "data\maps\paths5.ipl"
Loading default scene "data\maps\cull.ipl"
Loading default scene "data\maps\tunnels.ipl"
Loading default scene "data\maps\occlusf.ipl"
Loading default scene "data\maps\occluveg.ipl"
Loading default scene "data\maps\occlula.ipl"
Loading default scene "data\maps\occluint.ipl"
Loading default scene "data\maps\audiozon.ipl"
Loading default train track "data\paths\tracks.dat"
Loading default train track "data\paths\tracks3.dat"
Loading default train track "data\paths\tracks2.dat"
Loading default train track "data\paths\tracks4.dat"
Opening file for streaming "MODELS\PLAYER.IMG"
Loading default clothes rules "DATA\CLOTHES.DAT"
Loading default water level "DATA\water.dat"
Loading default ped relationship data "DATA\PED.DAT"
Loading default weapon data "DATA\WEAPON.DAT"
Loading default ped groups "PEDGRP.DAT"
Loading default car groups "CARGRP.DAT"
Starting injected cleo script search 0C69F668 for version '0'...
Finishing injected cleo script search 0C69F668...
Starting injected cleo script search 0C69F668 for version '4'...
Starting injected cleo script search 0C69F668 for version '3'...
Loading default action reaction stats "DATA\AR_STATS.DAT"
Loading default stat update conditions "DATA\STATDISP.DAT"
Loading default shopping data "data\shopping.dat"
Loading default furniture data "data\furnitur.dat"
Loading default procedural objects "data\procobj.dat"
Removing imported model file at index 20000
Removing imported model file at index 20001
Removing imported model file at index 20002
Removing imported model file at index 20003
Removing imported model file at index 384
Removing imported model file at index 385
Removing imported model file at index 386
Removing imported model file at index 387
Removing imported model file at index 388
Removing imported model file at index 300
Removing imported model file at index 301
Removing imported model file at index 302
Removing imported model file at index 303
Shutting down Mod Loader...
Shutting down menu...
Mod Loader has been shutdown.
[/code]
em Ter 04 Ago 2015, 16:40
Instala isso para ver https://www.microsoft.com/en-us/download/confirmation.aspx?id=5555
Se ainda assim não funcionar, apaga a msvcr100d.dll que veio no mod e testa novamente
Mod Loader - Topico Oficial - Página 41 2ps4uxd
em Ter 04 Ago 2015, 17:05
@GameViciousNerdZ escreveu:Sim claro! Tenho 3 asi loaders
q? ham? wat? nao tem como ter 3 asi loader, somente 1 asi loader irá carregar os asi, e msm se fosse possível entao iria carregar os asi 3 vezes (wtf)
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 17:09
Junior tenho 3 asi,mas tipo tem 2 guardado em outras pastas e to usando um na pasta do gta sa (é claro,não sou tão burro quanto pareço '-') Fabio valeu ai vou tentar.
em Ter 04 Ago 2015, 17:11
kkkkkkkkkkkkk ata :v:
em Ter 04 Ago 2015, 17:14
@GameViciousNerdZ escreveu:Fabio valeu ai vou tentar.
De nada :v:
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 17:25
Fabio eu ja tenho o microsoft visual c+ (desde o 2008 até o 2013 o 2010 é 64 bits ,quiser eu mando print) e deletei o arquivo que voce falou la.Bom não mudou praticamente nada,mas a barrinha de loading do gta carregou mais rapido.O mod não carregou.Vou mandar o arquivo de log deenovo,talvez ajude em alguma coisa ou sei la.
Reading plugins.ini
Starting injected cleo script search 0C6EF668 for version '0'...
Finishing injected cleo script search 0C6EF668...
Starting injected cleo script search 0C6EF668 for version '4'...
Starting injected cleo script search 0C6EF668 for version '3'...
Obs:Não entendo nada de script ou sei la o que é isso...só pra deixar claro msm.
em Ter 04 Ago 2015, 17:28
Tem que ser 32 bits, o jogo é 32 bits e os ASIs também são 32 bits...
0x45A, o mesmo erro de antes... coloque os VC++ x86 (32bits)
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 17:36
Pronto,baixei e instalei.Sem alteracão.Quer o log denovo?Pode ir mandando ideias ai,qualquer coisa serve.
em Ter 04 Ago 2015, 17:41
@GameViciousNerdZ escreveu:Pronto,baixei e instalei.Sem alteracão.Quer o log denovo?Pode ir mandando ideias ai,qualquer coisa serve.
Seria bom ver o log para saber o código de erro do asi mudou.
Reiniciou o PC depois de instalar?
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 17:47
Vo mandar o log...ah não reiniciei o pc depois de instalar (Esse erro não é de deus cara...na moral kk.) Vo reiniciar agora.Log:
Reading plugins.ini
Ah mais uma coisa...voce é o cara que manja aqui,então vc tem alguma ideia do que pode ta acontecendo?(ué quem sabe eu consiga pensar em alguma coisa...quem sabe kk)
em Ter 04 Ago 2015, 17:53
@GameViciousNerdZ escreveu:Vo mandar o log...ah não reiniciei o pc depois de instalar (Esse erro não é de deus cara...na moral kk.) Vo reiniciar agora.Log:
Reading plugins.ini
Olhando o código da DLL parece que ela gosta de carregar alguns arquivos dela usando find file na pasta, acho que a unica coisa que sobrou para fazer é jogar todo o conteúdo do mod na pasta principal do jogo e não usar ele no modloader para ver se funciona...
Olhando em alguns sites de programação sobre esse erro 0x45A (1114) dá para tirar algumas conclusões:
Ou a própria DLL retornou algum valor estranho do DllMain (que é o que essa dll faz se não conseguir achar seus arquivos);
Ou ela não pode ser carregada (nesse caso seria por causa do VC++ redist, que foi o que você instalou).
Então o que sobrou para fazer é tirar o mod inteiro da pasta do modloader e colocá-lo na pasta raiz do jogo
@EDIT:
Achei uma coisa, um tanto, curiosa, no mod:
Ele realiza LoadLibrary (carregar outras dlls) dentro do DllMain, teoricamente o Windows não permite que você carregue outra dll de dentro do DllMain...
Só para testar uma teoria:
Renomeie aqueles arquivos .sp e .fp que vieram no mod para .asi, se não funcionar, coloque outra cópia deles com a extensão original, mas mantenha os .asi, vai que né
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 18:08
Arquivos .fp e .sp?Os que eu vi lá assim foram o FirstPerson.fp e o gui.sp (ou ao contrario...sei lá) ja renomeei eles e coloquei .asi nos dois.Agora não posso testar porque vou pro colegio.Ah e como voce disse,vo instalar o Fps v3.0 manualmente,instalando tudo normal msm.Até depois então...
em Ter 04 Ago 2015, 18:11
@GameViciousNerdZ escreveu:Arquivos .fp e .sp?Os que eu vi lá assim foram o FirstPerson.fp e o gui.sp (ou ao contrario...sei lá) ja renomeei eles e coloquei .asi nos dois.Agora não posso testar porque vou pro colegio.Ah e como voce disse,vo instalar o Fps v3.0 manualmente,instalando tudo normal msm.Até depois então...
Esses arquivos mesmo.
Vou continuar olhando o mod aqui, até depois.
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 23:20
Aqui estou denovo,renomeei os arquivos como voce pediu os resultados foram esses ai: http://prntscr.com/80yw9y arquivo de log:
Reading plugins.ini
Found file [0x00000001AA0AEB01] "FirstPerson.asi" with handler "gta3.std.asi"
Found file [0x00000001594B5AA5] "GUI.asi" with handler "gta3.std.asi"
Installing file "modloader\fps\firstperson.asi"
[ASI] Failed to load module "firstperson.asi"; errcode: 0x7E
Failed to Install file "modloader\fps\firstperson.asi"
Installing file "modloader\fps\gui.asi"
[ASI] Failed to load module "gui.asi"; errcode: 0x45A
Failed to Install file "modloader\fps\gui.asi"
Starting injected cleo script search 0C9AF668 for version '0'...
Finishing injected cleo script search 0C9AF668...
Starting injected cleo script search 0C9AF668 for version '4'...
Starting injected cleo script search 0C9AF668 for version '3'...
Novamente o mod não rodou.
em Ter 04 Ago 2015, 23:29
Não use eles no modloader, coloque na pasta principal
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 23:44
Ok.Vo instalar tudo manualmente.
GameViciousNerdZ
Desde : 02/08/2015
em Ter 04 Ago 2015, 23:55
O mesmo erro de antes.O log ta ai denovo: (vo sempre colocar o log de agora em diante)
Reading plugins.ini
Starting injected cleo script search 0D5EF5C8 for version '0'...
Finishing injected cleo script search 0D5EF5C8...
Starting injected cleo script search 0D5EF5C8 for version '4'...
Starting injected cleo script search 0D5EF5C8 for version '3'...
em Ter 04 Ago 2015, 23:57
O ASI Loader mostrou algum erro?
GameViciousNerdZ
Desde : 02/08/2015
em Qua 05 Ago 2015, 00:00
Sim,exatamente o mesmo erro daquele print que eu mandei: http://prntscr.com/80yw9y
em Qua 05 Ago 2015, 00:02
Volte os nomes originais dos arquivos do mod lá.
GUI.fp e FirstPerson.sp
Lembrando que esses arquivos devem estar junto com o Hooks.asi na pasta raiz do jogo (onde está o .exe)
GameViciousNerdZ
Desde : 02/08/2015
em Qua 05 Ago 2015, 00:12
http://prntscr.com/80zamy não ha erros,mas o mod NÃO carrega. (ah outra coisa:toda vez que eu vou testar,eu clico em new game,não usando nenhum save.) Eu tinha errado um arquivo (notei no print,então editei esse comentario umas 2 vezes só pra constar) mesmo depois de arrumar não rodou.
GameViciousNerdZ
Desde : 02/08/2015
em Qua 05 Ago 2015, 00:19
Esqueci de mandar o log!
Reading plugins.ini
Starting injected cleo script search 0D86F5E8 for version '0'...
Finishing injected cleo script search 0D86F5E8...
Starting injected cleo script search 0D86F5E8 for version '4'...
Starting injected cleo script search 0D86F5E8 for version '3'...
