em Qua 05 Ago 2015, 00:24
@__@
Tenta instalar o noDEP.asi http://mixmods.blogspot.com.br/2015/03/nodep-desativar-dep.html coloque um A no nome do noDEP.asi para garantir que ele seja carregado primeiro, ficando anoDEP.asi
Mod Loader - Topico Oficial - Página 42 226c0ef57f9d7520d171cbadc68b3c56
Mod Loader - Topico Oficial - Página 42 76561198069372249
GameViciousNerdZ
Desde : 02/08/2015
em Qua 05 Ago 2015, 00:34
Baixei o anoDEP.asi,coloquei esse nome ai nela,e coloquei ela na pasta do gta sa junto com o .exe ,sem alteracoes,o mod continua não funcionando.Log:
========================== Mod Loader 0.2.4 ==========================
Game version: GTA SA 1.0 US
Parsing command line
Loaded fallback menu fxt
Looking for plugins...
Reading plugins.ini
Plugin module "gta3\std.asi.dll" loaded as gta3.std.asi Feb 12 2015 22:09:09 by LINK/2012
CLEO library version 4030000 found at "CLEO.asi"
Plugin module "gta3\std.bank.dll" loaded as gta3.std.bank Feb 12 2015 22:08:44 by LINK/2012
Plugin module "gta3\std.data.dll" loaded as gta3.std.data Feb 12 2015 22:09:14 by LINK/2012
Plugin module "gta3\std.fx.dll" loaded as gta3.std.fx Feb 12 2015 22:08:29 by LINK/2012
Plugin module "gta3\std.movies.dll" loaded as gta3.std.movies Feb 12 2015 22:08:15 by LINK/2012
Plugin module "gta3\std.scm.dll" loaded as gta3.std.scm Feb 12 2015 22:08:17 by LINK/2012
Plugin module "gta3\std.sprites.dll" loaded as gta3.std.sprites Feb 12 2015 22:08:20 by LINK/2012
Plugin module "gta3\std.stream.dll" loaded as gta3.std.stream Feb 12 2015 22:08:53 by LINK/2012
Plugin module "gta3\std.text.dll" loaded as gta3.std.text Feb 12 2015 22:08:37 by LINK/2012
Plugin module "gta3\std.tracks.dll" loaded as gta3.std.tracks Feb 12 2015 22:08:41 by LINK/2012
Scanning files at "modloader\fps\"...
Mod Loader has started up!
Loading default plants surface properties "PLANTS.DAT"
Loading default anim association "DATA\ANIMGRP.DAT"
Loading default stream config "stream.ini"
Loading default fighting data "DATA\melee.dat"
Preloading level file "DATA\DEFAULT.DAT"
Preloading level file "DATA\GTA.DAT"
Loading default level file "DATA\GTA.DAT"
Loading preloaded level entries...
Opening file for streaming "data\paths\carrec.img"
Opening file for streaming "data\script\script.img"
Opening file for streaming "models\cutscene.img"
Loading default object types "data\default.ide"
Loading default object types "data\vehicles.ide"
Loading default object types "data\peds.ide"
Loading default object types "data\maps\generic\vegepart.ide"
Loading default object types "data\maps\generic\barriers.ide"
Loading default object types "data\maps\generic\dynamic.ide"
Loading default object types "data\maps\generic\dynamic2.ide"
Loading default object types "data\maps\generic\multiobj.ide"
Loading default object types "data\maps\generic\procobj.ide"
Loading default object types "data\maps\la\lan.ide"
Loading default object types "data\maps\la\lan2.ide"
Loading default object types "data\maps\la\las.ide"
Loading default object types "data\maps\la\las2.ide"
Loading default object types "data\maps\la\lae.ide"
Loading default object types "data\maps\la\lae2.ide"
Loading default object types "data\maps\la\law2.ide"
Loading default object types "data\maps\la\law.ide"
Loading default object types "data\maps\la\lawn.ide"
Loading default object types "data\maps\la\lahills.ide"
Loading default object types "data\maps\la\laxref.ide"
Loading default object types "data\maps\sf\sfn.ide"
Loading default object types "data\maps\sf\sfs.ide"
Loading default object types "data\maps\sf\sfse.ide"
Loading default object types "data\maps\sf\sfe.ide"
Loading default object types "data\maps\sf\sfw.ide"
Loading default object types "data\maps\sf\sfxref.ide"
Loading default object types "data\maps\vegas\vegasn.ide"
Loading default object types "data\maps\vegas\vegass.ide"
Loading default object types "data\maps\vegas\vegase.ide"
Loading default object types "data\maps\vegas\vegasw.ide"
Loading default object types "data\maps\vegas\vegaxref.ide"
Loading default object types "data\maps\country\countryn.ide"
Loading default object types "data\maps\country\countn2.ide"
Loading default object types "data\maps\country\countrys.ide"
Loading default object types "data\maps\country\countrye.ide"
Loading default object types "data\maps\country\countryw.ide"
Loading default object types "data\maps\country\counxref.ide"
Loading default object types "data\maps\interior\int_la.ide"
Loading default object types "data\maps\interior\int_sf.ide"
Loading default object types "data\maps\interior\int_veg.ide"
Loading default object types "data\maps\interior\int_cont.ide"
Loading default object types "data\maps\leveldes\levelmap.ide"
Loading default object types "data\maps\leveldes\levelxre.ide"
Loading default object types "data\maps\interior\gen_int1.ide"
Loading default object types "data\maps\interior\gen_int2.ide"
Loading default object types "data\maps\interior\gen_intb.ide"
Loading default object types "data\maps\interior\gen_int3.ide"
Loading default object types "data\maps\interior\gen_int4.ide"
Loading default object types "data\maps\interior\gen_int5.ide"
Loading default object types "data\maps\interior\savehous.ide"
Loading default object types "data\maps\interior\stadint.ide"
Loading default object types "data\maps\leveldes\seabed.ide"
Loading default object types "data\maps\interior\props.ide"
Loading default object types "data\maps\interior\props2.ide"
Loading default object types "data\maps\interior\propext.ide"
Loading default object types "data\maps\veh_mods\veh_mods.ide"
Loading default object types "data\txdcut.ide"
Loading default vehicle colours "DATA\CARCOLS.DAT"
Loading default vehicle upgrades "DATA\CARMODS.DAT"
Initializing the streaming...
Loading default scene "data\map.zon"
Loading default scene "data\info.zon"
Loading default scene "data\maps\la\lan.ipl"
Loading default scene "data\maps\la\lan2.ipl"
Loading default scene "data\maps\la\las.ipl"
Loading default scene "data\maps\la\las2.ipl"
Loading default scene "data\maps\la\lae.ipl"
Loading default scene "data\maps\la\lae2.ipl"
Loading default scene "data\maps\la\law.ipl"
Loading default scene "data\maps\la\lawn.ipl"
Loading default scene "data\maps\la\law2.ipl"
Loading default scene "data\maps\la\lahills.ipl"
Loading default scene "data\maps\sf\sfn.ipl"
Loading default scene "data\maps\sf\sfs.ipl"
Loading default scene "data\maps\sf\sfse.ipl"
Loading default scene "data\maps\sf\sfe.ipl"
Loading default scene "data\maps\sf\sfw.ipl"
Loading default scene "data\maps\vegas\vegasn.ipl"
Loading default scene "data\maps\vegas\vegass.ipl"
Loading default scene "data\maps\vegas\vegase.ipl"
Loading default scene "data\maps\vegas\vegasw.ipl"
Loading default scene "data\maps\country\countryn.ipl"
Loading default scene "data\maps\country\countn2.ipl"
Loading default scene "data\maps\country\countrys.ipl"
Loading default scene "data\maps\country\countrye.ipl"
Loading default scene "data\maps\country\countryw.ipl"
Loading default scene "data\maps\interior\int_la.ipl"
Loading default scene "data\maps\interior\int_sf.ipl"
Loading default scene "data\maps\interior\int_veg.ipl"
Loading default scene "data\maps\interior\int_cont.ipl"
Loading default scene "data\maps\interior\gen_int1.ipl"
Loading default scene "data\maps\interior\gen_int2.ipl"
Loading default scene "data\maps\interior\gen_intb.ipl"
Loading default scene "data\maps\interior\gen_int3.ipl"
Loading default scene "data\maps\interior\gen_int4.ipl"
Loading default scene "data\maps\interior\gen_int5.ipl"
Loading default scene "data\maps\interior\stadint.ipl"
Loading default scene "data\maps\interior\savehous.ipl"
Loading default scene "data\maps\leveldes\levelmap.ipl"
Loading default scene "data\maps\leveldes\seabed.ipl"
Loading default scene "data\maps\paths.ipl"
Loading default scene "data\maps\paths2.ipl"
Loading default scene "data\maps\paths3.ipl"
Loading default scene "data\maps\paths4.ipl"
Loading default scene "data\maps\paths5.ipl"
Loading default scene "data\maps\cull.ipl"
Loading default scene "data\maps\tunnels.ipl"
Loading default scene "data\maps\occlusf.ipl"
Loading default scene "data\maps\occluveg.ipl"
Loading default scene "data\maps\occlula.ipl"
Loading default scene "data\maps\occluint.ipl"
Loading default scene "data\maps\audiozon.ipl"
Loading default train track "data\paths\tracks.dat"
Loading default train track "data\paths\tracks3.dat"
Loading default train track "data\paths\tracks2.dat"
Loading default train track "data\paths\tracks4.dat"
Opening file for streaming "MODELS\PLAYER.IMG"
Loading default clothes rules "DATA\CLOTHES.DAT"
Loading default water level "DATA\water.dat"
Loading default ped relationship data "DATA\PED.DAT"
Loading default weapon data "DATA\WEAPON.DAT"
Loading default ped groups "PEDGRP.DAT"
Loading default car groups "CARGRP.DAT"
Starting injected cleo script search 0D60F7C8 for version '0'...
Finishing injected cleo script search 0D60F7C8...
Starting injected cleo script search 0D60F7C8 for version '4'...
Starting injected cleo script search 0D60F7C8 for version '3'...
Loading default action reaction stats "DATA\AR_STATS.DAT"
Loading default stat update conditions "DATA\STATDISP.DAT"
Loading default shopping data "data\shopping.dat"
Loading default furniture data "data\furnitur.dat"
Loading default procedural objects "data\procobj.dat"
Removing imported model file at index 20000
Removing imported model file at index 20001
Removing imported model file at index 20002
Removing imported model file at index 20003
Removing imported model file at index 384
Removing imported model file at index 385
Removing imported model file at index 386
Removing imported model file at index 387
Removing imported model file at index 388
Removing imported model file at index 300
Removing imported model file at index 301
Removing imported model file at index 302
Removing imported model file at index 303
Shutting down Mod Loader...
Shutting down menu...
Mod Loader has been shutdown.
em Qua 05 Ago 2015, 00:38
Não faço ideia do que está acontecendo, o jeito seria baixar e reinstalar todos os mods, CLEO, modloader, etc. e se não funcionar, talvez só entrando em contato com o modder do FPS mod...
Um dos motivos de não estar funcionando seria porque o mod está tentando fazer carregamento de dlls dentro do DllMain, só que dessa forma não deveria estar funcionando em lugar nenhum, então sei lá...
GameViciousNerdZ
Desde : 02/08/2015
em Qua 05 Ago 2015, 00:45
Vish...to vendo que o erro não é de deus mesmo kkkk.É uma pena,mas ja reinstalei tudo denovo e denovo e denovo,não sei se faria alguma diferença tentar,mas irei.Pode ser besteira eu falar isso,mas aposto que até foi um pequeno desafio pra ti né kk.Bom é isso,valeu pela ajuda ai,vou encontrar outro FPS mod,porque o mod loader eu não tiro por nada,muito util.Não sei se todos os FPS que tem por ai rodam com o mod loader,mas vou tentar.Valeu ai!!!!
em Qua 05 Ago 2015, 00:48
@GameViciousNerdZ escreveu:Vish...to vendo que o erro não é de deus mesmo kkkk.É uma pena,mas ja reinstalei tudo denovo e denovo e denovo,não sei se faria alguma diferença tentar,mas irei.Pode ser besteira eu falar isso,mas aposto que até foi um pequeno desafio pra ti né kk.Bom é isso,valeu pela ajuda ai,vou encontrar outro FPS mod,porque o mod loader eu não tiro por nada,muito util.Não sei se todos os FPS que tem por ai rodam com o mod loader,mas vou tentar.Valeu ai!!!!
Pois é kkkk foi um pequeno desafio kkkk eu nunca tinha feito engenharia reversa em mod que não fosse meu para ver o que poderia estar dando problemas kkkk
Mas beleza, de nada, qualquer coisa é só postar. :v:
em Qua 22 Jun 2016, 14:15
Mod Loader v0.3.4
  • Suporte ao GTA III, Vice City e San Andreas.
  • Suporte ao limite de ids de 32 bits do Fastman92 Limit Adjuster.
Download
Mod Loader - Topico Oficial - Página 42 2ywzqdu
em Qua 22 Jun 2016, 22:25
vish, agora sim megusta2
Mod Loader - Topico Oficial - Página 42 Ac2CNFT
Mod Loader - Topico Oficial - Página 42 2n6t5d4
Deadstroke
Desde : 08/02/2016
em Sab 18 Nov 2017, 12:50
Não sei se já viram, mas isso aqui procede?
Não me parece bom, o cara fez até um .dll loader, não sei pra que? (se for para ENB pelo menos, e nem me lembro se usam .dll)
em Sab 18 Nov 2017, 12:57
fizeram até um logo novo ;-;
Victor_Troquetti
em Sab 18 Nov 2017, 13:22
Uma sugestão, no menu do modloader ter pastas e subpastas, exemplo, vc poderia criar pastar pra separar tipos de mods, Fix, Melhorias, Carros, Armas, e dentro dessas pastas vc teria a pasta dos mods podendo desativar algum mod dentro da pasta, voce poderia desativar algum mod na pasta fix e deixar oa outros ativados.
em Sab 18 Nov 2017, 13:26
Daria pra desativar tudo o que tem dentro de uma pasta? Tipo, desativar a pasta "Fix" e todos os mods que tem dentro...
Victor_Troquetti
em Sab 18 Nov 2017, 14:43
Tambem... Nossa, isso organizaria mt os mods
em Sab 18 Nov 2017, 14:53
@Hue escreveu:Daria pra desativar tudo o que tem dentro de uma pasta? Tipo, desativar a pasta "Fix" e todos os mods que tem dentro...
Dentro do .ini do modloader tem configurações de ignorar mods/arquivos específicos.
em Sab 18 Nov 2017, 15:03
Acho que o link não mexerá mais no modloader nessa vida: http://gtaforums.com/topic/669520-mod-loader/page-57#entry1069834228
em Sab 18 Nov 2017, 15:56
nunca diga nunca :)
Programador - Intermediário
Desde : 02/06/2017
Idade : 100
em Sab 18 Nov 2017, 18:18
Última edição por Veryzon em Dom 01 Jul 2018, 08:00, editado 1 vez(es)
em Sab 18 Nov 2017, 18:46
Geneilson poderia adotar o Mode Loader :Genial:
mas ele ainda tem muita resistência ao mesmo ;-;
em Dom 19 Nov 2017, 10:29
@Veryzon escreveu:Seguindo o quê o @Thelost disse, eu também penso que o Mod Loader está necessitando de ser adotado. Apesar de ser um projeto muito complexo.
Já foi, silent vai lançar uma PR logo.
Deadstroke
Desde : 08/02/2016
em Dom 19 Nov 2017, 14:30
A questão não é outro continuar o tópico. Esse cara posta o mod loader "0.3.8" como se fosse a versão oficial, mas é uma versão dele. Deveria colocar como unoffical mod loader 0.3.8. Não dá para confiar numa versão dessas, só acho;
Fora que também não quer que ninguém poste em outros lugares, rídiculo como o Junior disse, e também ele nem posta o source para que verifiquem como foi feito (se foi bem feito).
O Link não exatamente permissão para ele, ele disse mais um "Como não trabalharei mais com isso, pode fazer o que bem entender...."
@Thelost escreveu:
O que seria uma PR? O Silent postou uma versão não oficial (humildemente diferente do outro cara), mas não vi nada que ele fosse atualizar mais depois...
Queria muito, principalmente para corrigir bugs e erros do mod e ser compatível com o GTA Underground pelo menos em ambos serem usados ao mesmo tempo...
Desde : 02/06/2017
Idade : 100
em Dom 19 Nov 2017, 15:04
Última edição por Veryzon em Dom 01 Jul 2018, 07:59, editado 1 vez(es)
em Dom 19 Nov 2017, 19:06
Raisins Face
