Re: Ciência e tal
em Ter 15 Set 2015, 11:22
Os fatos tão aí oh, só clicar nos links.
Re: Ciência e tal
em Ter 15 Set 2015, 11:51
A ciência quântica é contra a ciência atual aceita.
Re: Ciência e tal
em Ter 15 Set 2015, 12:25
Deep learning, despite its remarkable successes, is a young field. While models called artificial neural networks have been studied for decades, much of that work seems only tenuously connected to modern results.
It’s often the case that young fields start in a very ad-hoc manner. Later, the mature field is understood very differently than it was understood by its early practitioners. For example, in taxonomy, people have grouped plants and animals for thousands of years, but the way we understood what we were doing changed a lot in light of evolution and molecular biology. In chemistry, we have explored chemical reactions for a long time, but what we understood ourselves to do changed a lot with the discovery of irreducible elements, and again later with models of the atom. Those are grandiose examples, but the history of science and mathematics has seen this pattern again and again, on many different scales.
Ih. que conveniente.
http://colah.github.io/posts/2015-09-NN-Types-FP/
Re: Ciência e tal
em Ter 15 Set 2015, 12:33
"but what we understood ourselves to do changed a lot with the discovery of irreducible elements"
Será que finalmente estão admitindo, pelo menos? :)
Re: Ciência e tal
em Ter 15 Set 2015, 14:23
@Hue escreveu:máquinas perpétuas :v
Espero que você realmente não tenha achado que essas maquinas são perpetuas.
Re: Ciência e tal
em Ter 15 Set 2015, 14:49
@Thelost escreveu:
Se a física está errada, como construímos as coisas baseadas nela então?
^^^ talvez por isso muitas pontes, prédios e aviões caem ainda hoje...
mas cai por causa da gravidade philosoraptor philosoraptor philosoraptor
Fuch That Guy
mas ele quis dizer coisas como experimentos e usar cálculos para enviar foguetes e tudo mais, nao sei de onde vc tirou q os aviões e predios caem por erros da física...
sua lógica eh: deu uma pane no motor = os físicos erraram philosoraptor vou pedir pro Stephen Hawking arrumar meu carro, ele deve ser um bom mecânico
Re: Ciência e tal
em Ter 15 Set 2015, 16:07
^^^ Erros de teoria fazem as coisas caírem.  Ou você acha que uma ponte pode ser construída sem levar todos os parâmetros conhecidos em conta?
Depois que caiu é fácil prever :v
Re: Ciência e tal
em Ter 15 Set 2015, 16:32
Ué, mas esse tipo de comportamento apresentado no vídeo (ressonância) é previsto pela física. Foi erro de engenharia, erro humano.
Re: Ciência e tal
em Ter 15 Set 2015, 16:50
Re: Ciência e tal
em Ter 15 Set 2015, 19:37
@Hue escreveu:^^^
A ressonância foi descoberta por Galileu Galilei quando começou suas pesquisas com pêndulos e cordas musicais no começo de 1602.
Re: Ciência e tal
em Ter 15 Set 2015, 19:59
edit:
subindo a mensagem aqui
Nex' escreveu:
@Hue escreveu:^^^
Título : Green River
Re: Ciência e tal
em Ter 15 Set 2015, 20:15
Hue acaba de tomar uma refutada.
scoreee
Re: Ciência e tal
em Ter 15 Set 2015, 21:16
@Junior_Djjr escreveu::) :) :)
edit:
Nex' escreveu:
@Hue escreveu:^^^
Então porque será que ignoraram a descoberta de Galileu Galilei? Será que pensaram que ele era um conspirador? :)
Re: Ciência e tal
em Ter 15 Set 2015, 21:44
Acho que os engenheiros nem cogitaram a possibilidade das vibrações do vento atingir a ressonância da ponte e fazer ela vibrar de forma rítmica lol
"Os grandes defeitos da ponte foram a sua enorme falta de rigidez transversal e torsional, pois estava ausente o reticulado por baixo do tabuleiro, e a frente aerodinâmica do perfil"
Erro de engenharia, humanos.
Re: Ciência e tal
em Ter 15 Set 2015, 22:46
q idiotice de assunto denilson gostoso
são coisas tão óbvias, e ainda eh necessário tentar provar...
mano, tentando provar q foi um erro humano de um engenheiro e não um erro de física, tipo, mano...
COLOQUEI O MEU LÁPIS DE LADO NUMA SUPERFÍCIE INCLINADA E ELE CAIU, MALDITO ISAC Q ERROU NA TEORIA DA GRAVIDADE
mano, vamo mudar de assunto, pelamor ohgodwhy
Re: Ciência e tal
em Ter 15 Set 2015, 23:19
^^^ É o que eu disse: Depois que acontece é fácil falar...
Nex' escreveu:Acho que os engenheiros nem cogitaram a possibilidade das vibrações do vento atingir a ressonância da ponte e fazer ela vibrar de forma rítmica lol
Eles nem cogitaram a possibilidade porque estavam errados sobre o que acreditavam de física; Acreditavam que aquilo jamais poderia acontecer da forma que aconteceu na ponte. Não foi um mero erro, foi uma crença de que o modo que construíam estava certo. Muita coisa mudou por conta deste incidente.
Re: Ciência e tal
em Qua 16 Set 2015, 00:09
@Hue escreveu:^^^ É o que eu disse: Depois que acontece é fácil falar...
eu zoo com seu raciocínio e vc ainda concorda, wat
me lembrou esse cara:
https://www.facebook.com/PerolasMixMods/photos/a.290554087783511.1073741828.290521217786798/456539157851669/?type=1&permPage=1
Eles nem cogitaram a possibilidade porque estavam errados sobre o que acreditavam de física; Acreditavam que aquilo jamais poderia acontecer da forma que aconteceu na ponte. Não foi um mero erro, foi uma crença de que o modo que construíam estava certo. Muita coisa mudou por conta deste incidente.[/quote]blz, e oq a física tem a ver com os engenheiros q acreditavam q o modo q eles construíram estava correto?
vc culpou a física por isso, mano... ohgodwhy os engenheiros fazem uma coisa errada, cai tudo, e a culpa eh da física
a culpa eh do estudos dos engenheiros, ou então simplesmente um erro humano deles
Re: Ciência e tal
em Qua 16 Set 2015, 09:43
@Junior_Djjr escreveu:blz, e oq a física tem a ver com os engenheiros q acreditavam q o modo q eles construíram estava correto?
Não foi erro dos engenheiros, só a partir do acontecimento que é considerado erro. Erro humano só é considerado quando se estabelece um padrão, antes disso é erro do método. Eles estavam errados quanto ao que acreditavam desse comportamento físico dos materiais usados na ponte até então. Físicos e engenheiros andam de mãos dadas. Muitos engenheiros calculistas tem doutorado em Física.
E essa não foi a única ponte que caiu por causa disso, essa deu sorte que foi filmada.
Re: Ciência e tal
em Qua 16 Set 2015, 10:32
PUTA QUE PARIU, ENTÃO MOSTRA AÍ A MATEMÁTICA QUEBRANDO, DESGRAÇA.
MOSTRA A BOCETA DA FÓRMULA QUE FEZ O AVIÃO CAIR.
PUTA QUE PARIU, MANO, QUE IGNORÂNCIA DO CARALHO.
EU NÃO ESTUDO FÍSICA PRA VER UM PALHAÇO DE HUMANAS FALAR MERDA.
Re: Ciência e tal
em Qua 16 Set 2015, 11:11
Re: Ciência e tal
em Qua 16 Set 2015, 11:48
@Thelost escreveu:PUTA QUE PARIU, ENTÃO MOSTRA AÍ A MATEMÁTICA QUEBRANDO, DESGRAÇA.
não faz sentido o que você escreve.
Re: Ciência e tal
em Qua 16 Set 2015, 12:08
"O AVIÃO CAIU, A '''''''''''''''FÍSICA''''''''''''''''''' ESTÁ ERRADA".
Re: Ciência e tal
em Qua 16 Set 2015, 12:11
Se o projeto foi feito com base na física atual e algo saiu fora do previsto... quem está errado? A teoria. precisa ser revista truestory
Re: Ciência e tal
em Qua 16 Set 2015, 12:42
não posso mandar nada legal que o Hue vem estragar
ve se não estraga esse possível grande avanço agora:
http://canaltech.com.br/noticia/ciencia/primeiro-transplante-de-cabeca-da-historia-esta-marcado-para-2017-49061/
Re: Ciência e tal
em Qua 16 Set 2015, 14:06
^^^ cara fiquei sabendo disso
Mas já tentaram fazer na Rússia com cachorros... Deu certo por algumas horas, mas o cachorro morreu.
Re: Ciência e tal
