Desde : 20/06/2013
em Seg 28 Dez 2015, 18:21
Sei lá o que esta acontecendo.... Antigamente eu sempre usei ele, agora que fiz uma instalação limpa do SA quis botar o Parking e esta dando erro... Quando esta carregando o arquivo Save a barrinha carrega ate a metade, freia, e o jogo crasha...
Essa é o LOG:
Game version: GTA SA 1.0 US
Unhandled exception at 0x015632B0 in gta_sa.exe (+0x11632b0): 0xC0000005: Access violation writing location 0x00000028.
    Register dump:
        EAX: 0x00000000  EBX: 0x0453B110  ECX: 0xC9742400  EDX: 0x000000FF
        EDI: 0x0023F4A4  ESI: 0x00000000  EBP: 0x0023F2B8  EIP: 0x015632B0
        ESP: 0x0023F2A0  EFL: 0x00010246  CS: 0x0000001B   SS: 0x00000023
        GS: 0x00000000   FS: 0x0000003B   ES: 0x00000023   DS: 0x00000023
    Stack dump:
        0x0023F2A0:  0023F4A4 00858BDC 0023F2DA FFFFFFFF 044E7250 0023F4A4
        0x0023F2B8:  0023F31C 044FC011 0023F328 0023F46C 0023F330 016E364C
        0x0023F2D0:  656E6C6A 632E6E6F 12006C6F 0023F58C 04645418 0023F314
        0x0023F2E8:  044ED875 00000078 00000800 0023F4A4 04612CE1 00000017
        0x0023F300:  0023F33C 0023F314 0450186D 00000000 0023F358 0451B288
        0x0023F318:  00000000 0023F364 044FF3AF 0023F4A4 0023F4A4 000061A8
        0x0023F330:  0451F144 016E35C0 0023F36C 0023F360 0023F330 00000000
        0x0023F348:  0023F46C 016E35C0 016E3648 FFFFFFFF 0023F3A4 0451B970
        0x0023F360:  00000000 0023F38C 04501AFE 0451F144 016E35C0 0023F428
        0x0023F378:  0023F388 0023F36C 00000000 0023F330 016E3638 0023F3B0
        base: 0x00040000   top: 0x0023F2A0   bottom: 0x00240000
    Backtrace (may be wrong):
        =>0x015632B0 in gta_sa.exe (+0x11632b0) (0x0023F2B8)
          0x044FC011 in std.stream.dll (+0x1c011) (0x0023F31C)
          0x044FF3AF in std.stream.dll (+0x1f3af) (0x0023F364)
          0x04501AFE in std.stream.dll (+0x21afe) (0x0023F38C)
          0x044E55F9 in std.stream.dll (+0x55f9) (0x0023F3B0)
          0x04502D57 in std.stream.dll (+0x22d57) (0x0023F458)
          0x0450223C in std.stream.dll (+0x2223c) (0x0023F464)
          0x005B6310 in gta_sa.exe (+0x1b6310) (0xFFFFFFFF)
Shutting down Mod Loader...
Shutting down menu...
Mod Loader has been shutdown.
Instalei tudo como diz no 'Leia-me'... A unica diferença é que o que tem que ser colocado no gta3.img eu coloco numa pasta dentro do Modloader. Seriam os arquivos COL, DFF e TXD
flw.
em Seg 28 Dez 2015, 18:32
Problema ao carregar os arquivos dff txd e col no modloader msm
Lembrando q .col precisa de linha de carregamento, como dito no tutorial do modloader
Desde : 20/06/2013
em Seg 28 Dez 2015, 20:30
Afff, então é isso mesmo... Vou conferir, depois comento se dar certo.
Valeu!
Desde : 20/06/2013
em Seg 28 Dez 2015, 22:15
Deu certo não! O LOG não mudou, mais pulou uma mensagem de "offset: 01163b0"
Estou achando que o problema é dentro do arquivo "gta.dat". Antes porque instalei no Modloader, mais agora é porque tinha desinstalado o MOD sem apagar o que carreguei no "gta.dat" e deu o mesmo erro: Barrinha carregando ate a metade (Sinal de erro no dat?) e fechando o jogo.
Estou achando que algum outro MOD é incompatível com este aqui.
em Seg 28 Dez 2015, 23:03
O problema eh o col sim
Eh soh usar a lista de crash da MixMods
http://mixmods.blogspot.com.br/p/lista-de-crash-e-solucoes.html
Erro: 0x015632B0
Tipo: Crash no carregamento
Problema: Bateu o limite de arquivos COL
Solução 1: Faça os arquivos COL carregarem pelo Mod Loader usando uma linha de carregamento.
Coloque o .col numa pasta dentro do Modloader (por exemplo "Modloader\alguma pasta\test.col"), crie um .txt nesta mesma pasta e dentro do .txt coloque: "COLFILE 0 Modloader\alguma pasta\test.col", faça isso com todos os seus arquivos .col (podem ser tudo no mesmo .txt). Se você não entendeu, tente ler a mesma coisa explicada em outra forma no tutorial do Mod Loader na sessão "Instalando arquivos COL".
Solução 2: Use algum Limit Adjuster para aumentar o limite de COL (não recomendado, pode bugar o jogo)
Desde : 20/06/2013
em Ter 29 Dez 2015, 05:29
Arrumei como vc falou o arquivo COL. (BLZ!)
Porem o mod não funfa! Mas já não fecha o jogo nem da erro nenhum....
Fiz alguns test:
O quadrado que delimita a área da garagem não aparece.
Para maior segurança instalei os arquivos "TXD" e "DFF" dentro do "gta3.img". Não seria esse o problema.
Mesmo assim coloquei um carro na área que eu sei que deveria estar o setor da garagem: Não guarda nada.
Ou seja, é criado um arquivo "sav" em "Meus documentos\GTA San Andreas User Files\grgx" e em "GTA San Andreas\cleo\cleo_saves", mas, no jogo não aparece carro nenhum!
No arquivo "cleo.log" vi que isto aqui é carregado:
29/12/2015 03:11:01.359 Loading custom script grgx_park.cs...
29/12/2015 03:11:01.359 Registering custom script named grgx_pa
O que não sei é si o arquivo "grgx.asi" esta carregando. Tem alguma ferramenta para verificar ?
Tem alguma outra dica? O que vcs acham?
philosoraptor
Desde : 20/06/2013
em Ter 29 Dez 2015, 15:25
Na verdade eu tenho a necessidade de instalar um Mod do tipo porque estou com aquele Bug da garagem que mesmo vazia, quando estou querendo guardar um carro nela, o jogo fala que já tem alcançado o limite de carros dentro. Isto estaria acontecendo na garagem da casa da mãe do CJ. E algumas vezes, depois de um tempo, esse Bug da nas outras garagens.
Engraçado que não achei nenhum Fix para este erro na Web.
Se alguém souber como arrumar, também seria ótimo!
Valeu!
em Ter 29 Dez 2015, 18:28
Nunca vi problemas assim pokerface
Pode ter sido causado por salvar o jogo com mods mal feitos, assim corrompe o save
Desde : 20/06/2013
em Ter 29 Dez 2015, 23:39
Pior que tenho um Save Game 100% limpo que peguei, acho que da Mix Mods mesmo (Faz muito tempo que só pego coisas dai)... E fiz o test com ele, justamente para tirar essa duvida, e deu certo não.
Aquele Bug da garagem eu já vi comentar em alguns foros... Porem nunca vi uma solução. Eu sempre achei que a única solução feita era a desses Mod como este aqui do Link2012.
Talvez, ele, o autor, saiba dalguma coisa que possa estar prejudicando seu Mod. Será?
em Qua 30 Dez 2015, 04:47
Então soh pode ser conflito, outro mod fazendo merda no seu jogo, basta procurar e removê-lo
Desde : 20/06/2013
em Qui 31 Dez 2015, 01:58
Não sei si vc leu isto, porque eu depois comentei de novo e vc pode ter perdido.
@fenrris escreveu:Arrumei como vc falou o arquivo COL. (BLZ!)
Fiz alguns test:
philosoraptor
Eu não sei como trabalha o "grgx_park". Pelo que estou vendo é que o arquivo Cleo esta carregando e funcionando (Em teoria)... Não tenho certeza mas poderia ser um problema do arquivo "*.ASI" deste mod?
O mod consta de:
grgx.asi
grgx_carpark.txd
grgx_carpark.dff
grgx_carpark.col
grgx_park.cs
grgx_park.IPL
grgx_park.ide
*Abra o arquivo "data\gta.dat" na pasta do seu SA, encontre a linha
IDE DATA\MAPS\leveldes\seabed.IDE
e coloque abaixo dela a linha:
IDE DATA\MAPS\grgx_park\grgx_park.IDE
*Agora no final do arquivo adicione a linha
IPL DATA\MAPS\grgx_park\grgx_park.IPL
Se eu tiver que duvidar de alguém, esse alguém, para mim (Na minha ignorância) seria o "grgx.asi"
Vcs que sabem... Pode ser isso mesmo?
Porque eu não sei se estou me enganando, mas acho que este mod parou de funcionar quando fiz upgrade do "ASI Loader", poderá ser isso???
em Qui 31 Dez 2015, 03:14
Tipo, o local da garagem nem apareceu, então obviamente o problema isso neh pokerface
Vc precisa da garagem para guardar o carro, sem a garagem vc não guarda ele
Vc não instalou direito o mapa, recomendo instalar por modloader, assim ele faria tudo isso por vc automaticamente (instalando as linhas etc)
Desde : 27/09/2015
Link : goo.gl/BgNT9p
em Qui 31 Dez 2015, 08:26
Cuidado, alguns .asi nao sao compativeis com o modloader. Assim voce deve coloca-los na pasta raiz do gta sa. Porem se voce nao recebeu um aviso diferente ao iniciar o GTA o .asi deve ter sido carregado normalmente.
importa.
ModLoader VIsual Editor WIP
Desde : 20/06/2013
em Qui 31 Dez 2015, 19:02
Sim, o ASI está fora do Mod Loader... Na verdade quase tudo esta onde deve estar, menos o arqui COL, por causa do limite, esse esta no Mod Loader.
Será que instalei errado o arquivo COL?
Eu fiz uma pasta: "COL_List". Esse é o caminho: "GTA San Andreas\modloader\MODs\COL_List"
Dentro dessa pasta o arquivo COL e o arquivo de texto juntos.
A linha do arquivo de texto é:  "COLFILE 0 Modloader\MODs\COL_List\grgx_carpark.col"
Depois, como já falei... Da para ver que não aparece o gráfico que esta dentro do TXD, o retângulo (O que somente seria uma coisa visual, mesmo não aparecendo, o setor, as coordenadas, podem estar funcionando sim).
Agora, sim, esta acontecendo alguma coisa, pois é criado o arquivo SAV dentro das pastas onde se guarda a informação.
Mesmo assim, o carro não é carregado de volta no espaço da garagem ao sair e voltar ao jogo.
Eu sei, é alguma incompatibilidade com algum mod, eu sempre usei, já conheço muito bem o "grgx", nunca deu problemas dentro do jogo. Porem nem ideia qual poderia ser esse maldito mod que esta me ferrando. Vou fazer uns testes na marra.... É foda!  ;)
em Qui 31 Dez 2015, 20:06
Não cara, se não está carregando o TXD o modelo ficaria branco, pois não teria a textura, sem textura = branco
O objeto em si não está instalado corretamente para aparecer no mapa, por isso vc não veh nada, pois o objeto não está lah
Desde : 20/06/2013
em Qui 31 Dez 2015, 22:52
E não pode acontecer que quem tem que chamar ao TXD entrar em jogo não esta chamando!?
O TXD esta no "gta3.img", o arquivo cleo esta sendo registrado como mostrei na LOG e também esta criando os SAV...
O que eu não sei o que faz, e se esta funcionando corretamente, é o arquivo ASI...
Mas vou descobrir o que é que esta acontecendo...
Pena que o LINK2012 não esta na área, ele poderia falar rapidinho para nos o que é que esta acontecendo, como funciona esse seu mod. Pelo menos alguma dica para testar!
em Sex 01 Jan 2016, 00:29
Não mano, desde o início do problema vc está tirando conclusões q não fazem sentido em como as coisas funcionam
Vc está vendo o objeto da "garagem" lah no mapa? Se não, simplesmente eh pq não foi adicionado o objeto lah, a instalação da modificação do mapa desse mod está errada
Desde : 20/06/2013
em Sex 01 Jan 2016, 18:26
Vc diz que instalei errado? Mas é muito simples de instalar e eu tenho experiência vei.... Alias botei ai como foi a instalação que fiz... O unico onde fiquei inseguro foi na novidade de instalar o COL por fora para quebrar o limite do jogo... Na verdade não sei se ele esta funcionando. Perguntei mas neguem me fala...
