Desde : 04/01/2017
em Qua 04 Jan 2017, 22:16
BOM EU TENHO UM FIGTH SPEED, POREM O SERVIDOR QUE EU LOGO, TEM PROTEÇOES E FAZ NAO PEGAR O MOD
0000: NOP
1@ = 1.0
0@ = 1
:First
if key_down 105// numpad9
1@ += 0.1
wait 100
0AD1: show_formatted_text_highpriority "fightSpeed rate = %0.1f" time 1000 1@
if key_down 99// numpad3
1@ -= 0.1
wait 100
0AB1: @setFightingRate 1 value 1@
jump @First
//0AB1: @setFightingRate 1 value 1@
:setFightingRate
0393: actor $PLAYER_ACTOR perform_animation "FightA_1" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightA_2" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightA_3" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightA_block" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightA_G" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightA_M" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FIGHTIDLE" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightShB" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightShF" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightSh_BWD" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightSh_FWD" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightSh_Left" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightSh_Right" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightB_1" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightB_2" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightB_3" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightB_block" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightB_G" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightB_IDLE" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightB_M" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "HitB_1" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "HitB_2" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "HitB_3" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightC_1" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightC_2" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightC_3" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightC_block" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightC_blocking" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightC_G" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightC_IDLE" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightC_M" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightC_Spar" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "HitC_1" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "HitC_2" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "HitC_3" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightD_1" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightD_2" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightD_3" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightD_bock" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightD_G" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightD_IDLE" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightD_M" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "HitD_1" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "HitD_2" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "HitD_3" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightKick" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "FightKick_B" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "Hit_fightkick" at 0@ times_normal_rate
0393: actor $PLAYER_ACTOR perform_animation "Hit_fightkick_B" at 0@ times_normal_rate
0AB2: ret 0
em Qua 04 Jan 2017, 22:22
Ou seja, você vem aqui num local para pedir ajuda a criar mods, com um script de hack pedindo para alguém editar o script para funcionar um servidor com segurança contra ele.
Haha, até parece... :v:
