Matheus Rivaldo
em Dom 15 Out 2017, 22:05
Sim.
CachorroLindo
Desde : 20/09/2016
Link : 2012
em Dom 19 Nov 2017, 15:45
LVAR_INT var1
LVAR_INT var2
LVAR_INT var3
LVAR_INT var4
LVAR_INT var5
GENERATE_RANDOM_INT_IN_RANGE 0 100 var1
GENERATE_RANDOM_INT_IN_RANGE 0 100 var2
GENERATE_RANDOM_INT_IN_RANGE 0 100 var3
GENERATE_RANDOM_INT_IN_RANGE 0 100 var4
GENERATE_RANDOM_INT_IN_RANGE 0 100 var5
main_loop:
IF var1 > 12
  var1 = 12
IF var1 < 12
  var1 = 12
IF var2 > 12
  var2 = 12
IF var2 < 12
  var2 = 12
IF var3 > 12
  var3 = 12
IF var3 < 12
  var3 = 12
IF var4 > 12
  var4 = 12
IF var4 < 12
  var4 = 12
IF var5 > 12
  var5 = 12
IF var5 < 12
  var5 = 12
IF var1 = 12
AND var2 = 12
AND var3 = 12
AND var4 = 12
AND var5 = 12
  PRINT_FORMATTED_NOW "Todas as variaveis sao 12: %d %d %d %d %d" 10000 var1 var2 var3 var4 var5
ELSE
  PRINT_STRING_NOW "Todas variaveis nao sao 12" 10000
GOTO main_loop
Pelo menos tá melhor do que oque eu fiz um tempo atrás no SannyBuilder
Script que eu fiz no Sanny
{$CLEO}
0000:
thread "Att"
var
    0@ : Integer
    1@ : Integer
    2@ : Integer
    3@ : Integer
    4@ : Integer
    5@ : Integer
:LABEL_A
    0@ = random(1,15)
    1@ = random(1,15)
    2@ = random(1,15)
    3@ = random(1,15)
    4@ = random(1,15)
    5@ = random(1,15)
 :LABEL_B
    0ADC:   test_cheat "CALCULA"
    jf @LABEL_B
:UM
    if 0@ <> 12
    jf @FIM
    if 0@ > 12
      0@ -= 1
      jump @DOIS
 :DOIS
  if 2@ <> 12
    jf @FIM
    if 2@ > 12
      2@ -= 1
      jump @DOIS_1
 :TRES
 if 3@ <> 12
    jf @FIM
    if 3@ > 12
      3@ -= 1
      jump @TRES_1
 :QUATRO
  if 4@ <> 12
    jf @FIM
    if 4@ > 12
      4@ -= 1
      jump @QUATRO_1
 :CINCO
  if 5@ <> 12
    jf @FIM
    if 5@ > 12
      5@ -= 1
      jump @CINCO_1
  :DOIS_1
  if 2@ <> 12
    jf @FIM
    if 2@ < 12
      2@ += 1
      jump @TRES
      :TRES_1
      if 3@ <> 12
    jf @FIM
    if 3@ < 12
      3@ += 1
      jump @QUATRO
      :QUATRO_1
      if 4@ <> 12
    jf @FIM
    if 4@ < 12
      4@ += 1
      jump @CINCO
      :CINCO_1
      if 5@ <> 12
    jf @FIM
    if 5@ < 12
      5@ += 1
      jump @DOIS
       :UM_1
        if 0@ <> 12
        jf @FIM
     if 0@ < 12
      0@ += 1
      jump @DOIS
   :FIM
   0@ = 12
   1@ = 12
   2@ = 12
   3@ = 12
   4@ = 12
   5@ = 12
 0ACD: show_text_highpriority "SUCESSO YEAH!!!" time 2000
  jump @LABEL_B
*Placa de vídeo : GTX 750 Ti 1gb
                        * Ram : 12GB DDR3
                        * Processador : Intel Core i5-3330
                        * Windows 10
                        * HD - 1 Terabyte
Matheus Rivaldo
em Dom 19 Nov 2017, 15:51
Você setou o valor das variáveis cara, coisa que foi dita para NÃO fazer. Era pra você fazer operações matemáticas que fariam os valores virarem 12.
CachorroLindo
Desde : 20/09/2016
Link : 2012
em Dom 19 Nov 2017, 15:56
KKKKKKK
Poxa bixo vou tentar fazer de novo Fuch That Guy
EDIT :
LVAR_INT var1
LVAR_INT var2
LVAR_INT var3
LVAR_INT var4
LVAR_INT var5
main_loop:
IF var1 > 12
 var1 /= 2
IF var1 < 12
  var1 += 24
IF var1 = 16
  var1 -= 4
IF var1 = 15
  var1 -= 3
IF var2 > 12
 var2 /= 2
IF var2 < 12
  var2 += 24
IF var2 = 16
  var2 -= 4
IF var2 = 15
  var2 -= 3
IF var3 > 12
 var3 /= 2
IF var3 < 12
  var3 += 24
IF var3 = 16
  var3 -= 4
IF var3 = 15
  var3 -= 3
IF var4 > 12
 var4 /= 2
IF var4 < 12
  var4 += 24
IF var4 = 16
  var4 -= 4
IF var4 = 15
  var4 -=3
IF var5 > 12
 var5 /= 2
IF var5 < 12
  var5 += 24
IF var5 = 16
  var5 -= 4
IF var5 = 15
  var5 -= 3
IF var1 = 12
AND var2 = 12
AND var3 = 12
AND var4 = 12
AND var5 = 12
GOTO main_loop
É, tá meio gambiarra mas pelo menos tentei
Última edição por CachorroLindo em Dom 19 Nov 2017, 16:55, editado 1 vez(es)
                        * Ram : 12GB DDR3
                        * Windows 10
                        * HD - 1 Terabyte
Matheus Rivaldo
em Dom 19 Nov 2017, 17:44
Acho que esse script não funciona (Fiz os cálculos com a calculadora do Windows pois estou sem o VSCode e o compilador).
CachorroLindo
Desde : 20/09/2016
Link : 2012
em Dom 19 Nov 2017, 17:49
Pelo menos aqui funfou
                        * Ram : 12GB DDR3
                        * Windows 10
                        * HD - 1 Terabyte
Matheus Rivaldo
em Dom 19 Nov 2017, 17:51
Se o valor for 13 acho que não funciona k. Faz o teste, seta as variáveis para 13 ao invés de gerar randomicamente.
Edit: testei e funcionou.
Boss
Desde : 14/12/2017
em Sab 16 Dez 2017, 18:37
Acho que poderia ter ficado melhor, mas só consegui fazer assim sem ajuda. Ao menos funcionou  (XD)
(seu cóSCRIPT_START
LVAR_INT var1
LVAR_INT var2
LVAR_INT var3
LVAR_INT var4
LVAR_INT var5
LVAR_INT guarda
guarda = var1 / 2
var1 = var1 * 30
var1 = var1 / guarda
var1 = var1 * 2
var1 = var1 / 10
guarda = var2 / 2
var2 = var2 * 30
var2 = var2 / guarda
var2 = var2 * 2
var2 = var2 / 10
guarda = var3 / 2
var3 = var3 * 30
var3 = var3 / guarda
var3 = var3 * 2
var3 = var3 / 10
guarda = var4 / 2
var4 = var4 * 30
var4 = var4 / guarda
var4 = var4 * 2
var4 = var4 / 10
guarda = var5 / 2
var5 = var5 * 30
var5 = var5 / guarda
var5 = var5 * 2
var5 = var5 / 10
Israel
em Seg 18 Dez 2017, 12:03
↑ Boa. :v:
PS: As variáveis podem ser declaradas todas numa só linha.
Edit: No tópico diz que deve-se usar condições. sec
Última edição por israel em Seg 18 Dez 2017, 18:57, editado 1 vez(es)
em Seg 18 Dez 2017, 15:27
Curiosidade: se você resolver esse exercício em C ou C++ (e provavelmente em muitas outras linguagens) da maneira mais fácil e o compilador estiver configurado pra fazer otimizações no código, ele simplesmente vai setar 12 nas variáveis, como pode ser visto aqui: https://godbolt.org/g/wBWLzY (spoiler)
nessa parte:
mov     dword ptr [rdi], 12
é simplesmente um:
number = 12;
Boss
Desde : 14/12/2017
em Seg 08 Jan 2018, 18:29
@israel escreveu:↑ Boa. :v:
Vlw. Sobre as variáveis eu vi no tutorial, mas acho mais organizado assim...
Spbre as condições verdade... (HMM) Vou terminar de ler todos os tutoriais e farei a atividade novamente.
Israel
em Seg 08 Jan 2018, 19:15
Nex' escreveu:Curiosidade: se você resolver esse exercício em C ou C++ (e provavelmente em muitas outras linguagens) da maneira mais fácil e o compilador estiver configurado pra fazer otimizações no código, ele simplesmente vai setar 12 nas variáveis, como pode ser visto aqui: https://godbolt.org/g/wBWLzY (spoiler)
nessa parte:
é simplesmente um:
number = 12;
Éeee, agora coloca um volatile aí.
em Seg 08 Jan 2018, 20:27
@israel escreveu:Éeee, agora coloca um volatile aí.
Pra quê?
Israel
em Seg 08 Jan 2018, 21:08
↑ Pro código que ele enviou:
em Seg 08 Jan 2018, 21:36
Tu não entendeu: pra que colocar volatile?
Israel
em Seg 08 Jan 2018, 21:50
↑ Acho que me expressei mal. Da forma que eu disse ficou parecendo que tem que usar volatile, mas na verdade, o @Nex' expôs uma curiosidade e eu quis responder com algo relacionado, no caso, o volatile.
Entendeu ? Ou eu que não entendi novamente ? Raisins Face
em Seg 08 Jan 2018, 21:58
Agora eu entendi, mas tu podia ter explicado. Esse impedimento de otimização com volatile é esperado. O papel principal do volatile é preservar leituras e escritas (e, em caso de funções, chamadas) como comportamento observável. Não tem motivo algum pra usar volatile ali, você não precisa deixar as operações locais visíveis pra algum observador de fora.
Israel
em Seg 08 Jan 2018, 22:13
Realmente deveria ter explicado, mas agora você já o fez, e melhor do que eu teria feito.
Cookiezi
Título : Há mais pessoas que desistem, do que fracassam
Desde : 16/01/2018
em Ter 16 Jan 2018, 13:45
NOP //Cookiezi .3.
WAIT 2000
LVAR_INT num1 num2 num3 num4 num5 //Aqui eu crio as var's
GENERATE_RANDOM_INT_IN_RANGE 0 100 num1 //Aqui eu seto as variáveis entre 0 e 99
GENERATE_RANDOM_INT_IN_RANGE 0 100 num2
GENERATE_RANDOM_INT_IN_RANGE 0 100 num3
GENERATE_RANDOM_INT_IN_RANGE 0 100 num4
GENERATE_RANDOM_INT_IN_RANGE 0 100 num5
WHILE NOT num1 = 12  //Aqui eu checo se as variáveis são iguais a doze, se forem menores, eu adiciono ou subtraio 1
   IF num1 > 12
       num1 -= 1
   ELSE
       num1 += 1
WHILE NOT num2 = 12
   IF num2 > 12
       num2 -= 1
   ELSE
       num2 += 1
WHILE NOT num3 = 12
   IF num3 > 12
       num3 -= 1
   ELSE
       num3 += 1
WHILE NOT num4 = 12
   IF num4 > 12
       num4 -= 1
   ELSE
       num4 += 1
WHILE NOT num5 = 12
   IF num5 > 12
       num5 -= 1
   ELSE
       num5 += 1
PRINT_FORMATTED_NOW "Todas as variaveis sao 12: %d %d %d %d %d" 10000 num1 num2 num3 num4 num5 //Aqui eu mostro o resultado final
em Qua 17 Jan 2018, 07:17
↑ o correto-básico do exercício é um código assim mesmo. De resto é "melhoria", por exemplo você pode melhorar usando array ao invés de 5 vars separadas.
em Qua 17 Jan 2018, 12:37
@Junior_Djjr escreveu:↑ o correto-básico do exercício é um código assim mesmo. De resto é "melhoria", por exemplo você pode melhorar usando array ao invés de 5 vars separadas.
Dava para inventar um outro exercício.
Paulo Henrique
Desde : 22/01/2018
em Sab 03 Fev 2018, 15:33
// fiz essa script que funcionou perfeitamente todo as variveis ficaran com o valor 12
LVAR_INT var1
LVAR_INT var2
LVAR_INT var3
LVAR_INT var4
lVAR_INT var5
var1 = 2
var2 = 3
var3 = 4
var4 = 5
var5 = 6
IF NOT var1 = var2 //dara verdadeiro pois as duas tem mesmos valores
var1 += 10 //agora somei +10 para a variavel var1 agora ela tem o valor 12
var2 += 9 // agora somei +10 para a variavel var1 agora ela tem o valor 12
ENDIF // fim da if
IF var3 = var4 // dara falso elas tem valores diferentes
var3 += 7
var4 += 7
ELSE // e se retornar falso o else manda o jogo ler aki
var3 += 8
var4 += 7
IF var5 >= 5 // vai checar se o valor da variavel e maior ou igual ao 5
var5 += 6 // vou somar o valor da variavel var5 com o valo 6 que da 12
ENDIF // fim da if
Matheus Rivaldo
em Sab 03 Fev 2018, 15:40
Você setou valores nas variáveis e somou o valor que faltava, não é assim que é pra fazer. É pra gerar valores aleatórios (e você não pode saber os valores) e arranjar algum jeito de transformá-los em 12 (sem setar, com operações matemáticas).
Última edição por Matheus Rivaldo em Sab 03 Fev 2018, 15:47, editado 1 vez(es)
em Sab 03 Fev 2018, 15:46
E coloca o código em spoiler
em Sab 03 Fev 2018, 16:53
Tanto que perdeu sentido o GENERATE_RANDOM_INT_IN_RANGE
