Desde : 18/12/2016
em Sex 12 Maio 2017, 13:49
Gostaria de que vocês pudessem avaliar esse simples mod que eu acabei fazendo para uso pessoal. A função dele é basicamente armazenar em 5 slots 5 coordenadas diferentes. Seja elas pegas de maneira única ou coletiva.
LVAR_INT scplayer
LVAR_FLOAT coord[24]
main_loop:
GET_PLAYER_CHAR 0 scplayer
GET_CHAR_COORDINATES scplayer coord[0] coord[1] coord[2]
GET_CHAR_COORDINATES scplayer coord[3] coord[4] coord[5]
GET_CHAR_COORDINATES scplayer coord[6] coord[7] coord[8]
GET_CHAR_COORDINATES scplayer coord[9] coord[10] coord[11]
GET_CHAR_COORDINATES scplayer coord[12] coord[13] coord[14]
//--SLOT 1--
    IF TEST_CHEAT "1coordx"
        PRINT_FORMATTED_NOW "X = %d" 850 coord[0]
        WRITE_FLOAT_TO_INI_FILE coord[0] "cleo/coordinates.ini" "Coordinates" "X"
    IF TEST_CHEAT "1coordy"
        PRINT_FORMATTED_NOW "Y = %d" 850 coord[1]
        WRITE_FLOAT_TO_INI_FILE coord[1] "cleo/coordinates.ini" "Coordinates" "Y"
    IF TEST_CHEAT "1coordz"
        PRINT_FORMATTED_NOW "Z = %d" 850 coord[2]
        WRITE_FLOAT_TO_INI_FILE coord[2] "cleo/coordinates.ini" "Coordinates" "Z"
    IF TEST_CHEAT "1allcoord"
        PRINT_FORMATTED_NOW "X=%d Y=%d X=%d" 850 coord[0] coord[1] coord[2]
//--SLOT 1--
//--SLOT 2--
    IF TEST_CHEAT "2coordx"
        PRINT_FORMATTED_NOW "X = %d" 850 coord[3]
        WRITE_FLOAT_TO_INI_FILE coord[3] "cleo/coordinates.ini" "Coordinates2" "X"
    IF TEST_CHEAT "2coordy"
        PRINT_FORMATTED_NOW "Y = %d" 850 coord[4]
        WRITE_FLOAT_TO_INI_FILE coord[4] "cleo/coordinates.ini" "Coordinates2" "Y"
    IF TEST_CHEAT "2coordz"
        PRINT_FORMATTED_NOW "Z = %d" 850 coord[5]
        WRITE_FLOAT_TO_INI_FILE coord[5] "cleo/coordinates.ini" "Coordinates2" "Z"
    IF TEST_CHEAT "2allcoord"
        PRINT_FORMATTED_NOW "X=%d Y=%d X=%d" 850 coord[3] coord[4] coord[5]
//--SLOT 2--
//--SLOT 3--
    IF TEST_CHEAT "3coordx"
        PRINT_FORMATTED_NOW "X = %d" 850 coord[6]
        WRITE_FLOAT_TO_INI_FILE coord[6] "cleo/coordinates.ini" "Coordinates3" "X"
    IF TEST_CHEAT "3coordy"
        PRINT_FORMATTED_NOW "Y = %d" 850 coord[7]
        WRITE_FLOAT_TO_INI_FILE coord[7] "cleo/coordinates.ini" "Coordinates3" "Y"
    IF TEST_CHEAT "3coordz"
        PRINT_FORMATTED_NOW "Z = %d" 850 coord[8]
        WRITE_FLOAT_TO_INI_FILE coord[8] "cleo/coordinates.ini" "Coordinates3" "Z"
    IF TEST_CHEAT "3allcoord"
        PRINT_FORMATTED_NOW "X=%d Y=%d X=%d" 850 coord[6] coord[7] coord[8]
//--SLOT 3--
//--SLOT 4--
    IF TEST_CHEAT "4coordx"
        PRINT_FORMATTED_NOW "X = %d" 850 coord[9]
        WRITE_FLOAT_TO_INI_FILE coord[9] "cleo/coordinates.ini" "Coordinates4" "X"
    IF TEST_CHEAT "4coordy"
        PRINT_FORMATTED_NOW "Y = %d" 850 coord[10]
        WRITE_FLOAT_TO_INI_FILE coord[10] "cleo/coordinates.ini" "Coordinates4" "Y"
    IF TEST_CHEAT "4coordz"
        PRINT_FORMATTED_NOW "Z = %d" 850 coord[11]
        WRITE_FLOAT_TO_INI_FILE coord[11] "cleo/coordinates.ini" "Coordinates4" "Z"
    IF TEST_CHEAT "4allcoord"
        PRINT_FORMATTED_NOW "X=%d Y=%d X=%d" 850 coord[9] coord[10] coord[11]
//--SLOT 4--
//--SLOT 5--
    IF TEST_CHEAT "5coordx"
        PRINT_FORMATTED_NOW "X = %d" 850 coord[12]
        WRITE_FLOAT_TO_INI_FILE coord[12] "cleo/coordinates.ini" "Coordinates5" "X"
    IF TEST_CHEAT "5coordy"
        PRINT_FORMATTED_NOW "Y = %d" 850 coord[13]
        WRITE_FLOAT_TO_INI_FILE coord[13] "cleo/coordinates.ini" "Coordinates5" "Y"
    IF TEST_CHEAT "5coordz"
        PRINT_FORMATTED_NOW "Z = %d" 850 coord[14]
        WRITE_FLOAT_TO_INI_FILE coord[14] "cleo/coordinates.ini" "Coordinates5" "Z"
    IF TEST_CHEAT "5allcoord"
        PRINT_FORMATTED_NOW "X=%d Y=%d X=%d" 850 coord[12] coord[13] coord[14]
//--SLOT 5--
GOTO main_loop
Digam-me os defeitos, ou se há como otimizar algo. Estou fazendo do jeito certo? Grato.
em Sex 12 Maio 2017, 13:52
Você criou 24 variáveis, só utilizou 14, você pegou as coordenadas do CJ 5 vezes, apenas 1 é necessária.
De resto tá bom.
em Sex 12 Maio 2017, 18:29
É o que o mathnoobsxx disse, não fez sentido esse negócio de pegar a mesma coordenada várias vezes em um monte de variáveis diferentes, é só pegar uma.
E você está mostrando na tela em "%d", o que é decimal usado pra números inteiros. Você tem que usar "%f"
Reputação : 150
em Sex 12 Maio 2017, 19:41
Posso esta errado, mas acho que pegar coordenadas assim seja errado, uma vez que só pode considerar coordenadas se tiver no minimo dois pontos de referencia (HMM)
em Sex 12 Maio 2017, 19:48
↑ é que ele não sabe como guardar X Y Z tudo ao mesmo tempo (o que é meio saco mesmo).
em Sex 12 Maio 2017, 23:36
Haviam formas MUITO mais simples e práticas de fazer o mesmo, mas fora os erros que já mencionaram, ficou bom. :)
