Título : Kick
Desde : 03/07/2015
em Ter 11 Jul 2017, 20:48
Since this wasn't done before and i would love to do it actually since i like Saints Row style , decided to make all the gangs car colors ( even the unused gangs )  completely customizable including the  primary and secondary color with a simple INI file. ;)
Just like that :
GangsCC.ini:
; Configuration file for mod Gangs CarColor Customizer created by Crspy
; you can check the color ids here : http://wiki.sa-mp.com/wiki/Vehicle_Color_IDs
; just put the id of your desired color :)
[Ballas]
Primary = 85
Secondary = 85
[Grove]
Primary = 86
Secondary = 86
[Vagos]
Primary = 6
Secondary = 6
[SFRifa]
Primary = 2
Secondary = 2
[DaNangBoys]
Primary = 69
Secondary = 69
[ItalianMafia]
Primary = 127
Secondary = 127
[Triads]
Primary = 17
Secondary = 17
[Aztecas]
Primary = 2
Secondary = 2
[RussianMafia]
Primary = 118
Secondary = 118
[Bikers]
Primary = 0
Secondary = 0
Source:
{$cleo}
0000:
if 8AAB:  not file_exists "CLEO\GANGSCC.INI"
    0ACD: show_text_highpriority "UNABLE TO LOAD ~B~'CLEO/GANGSCC.INI'" time 4000
    0A93: end_custom_thread
if 8AF0:  not 1@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "BALLAS" key "PRIMARY"
    1@ = -1
if 8AF0:  not 2@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "BALLAS" key "SECONDARY"
    2@ = -1
if 8AF0:  not 3@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "GROVE" key "PRIMARY"
    3@ = -1
if 8AF0:  not 4@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "GROVE" key "SECONDARY"
    4@ = -1
if 8AF0:  not 5@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "VAGOS" key "PRIMARY"
    5@ = -1
if 8AF0:  not 6@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "VAGOS" key "SECONDARY"
    6@ = -1
if 8AF0:  not 7@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "SFRIFA" key "PRIMARY"
    7@ = -1
if 8AF0:  not 8@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "SFRIFA" key "SECONDARY"
    8@ = -1
if 8AF0:  not 9@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "DaNangBoys" key "PRIMARY"
    9@ = -1
if 8AF0:  not 10@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "DaNangBoys" key "SECONDARY"
    10@ = -1
if 8AF0:  not 11@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "ITALIANMAFIA" key "PRIMARY"
    11@ = -1
if 8AF0:  not 12@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "ITALIANMAFIA" key "SECONDARY"
    12@ = -1
if 8AF0:  not 13@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "TRIADS" key "PRIMARY"
    13@ = -1
if 8AF0:  not 14@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "TRIADS" key "SECONDARY"
    14@ = -1
if 8AF0:  not 15@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "AZTECAS" key "PRIMARY"
    15@ = -1
if 8AF0:  not 16@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "AZTECAS" key "SECONDARY"
    16@ = -1
if 8AF0:  not 17@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "RUSSIANMAFIA" key "PRIMARY"
    17@ = -1
if 8AF0:  not 18@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "RUSSIANMAFIA" key "SECONDARY"
    18@ = -1
if 8AF0:  not 19@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "BIKERS" key "PRIMARY"
    19@ = -1
if 8AF0:  not 20@ = get_int_from_ini_file "CLEO\GANGSCC.INI" section "BIKERS" key "SECONDARY"
    20@ = -1
A loop that passes through all cars (on the street) structures and check if their Driver's Pedtype is one of the gangs' then execute the car color change, once !
0xB74494 - Contains a pointer to main struct
31@ : Car
21@ : Driver
22@ : pedtype
    0A8D: 29@ = read_memory 0xB74494 size 4 virtual_protect 0
    29@ += 0x4
    for 30@ = 0 to 27904 step 0x100
        0A8D: 31@ = read_memory 29@ size 1 virtual_protect 0
        000A: 29@ += 0x1
            0029: 31@ >= 0x00
            001B: 0x80 > 31@
            005A: 31@ += 30@
            046C: 21@ = car 31@ driver
            03F3: get_car 31@ primary_color_to 23@ secondary_color_to 24@
            056D:  actor 21@ defined
            jf continue
            089F: get_actor 21@ pedtype_to 22@
            if 22@ == 7
                if or
                803B: not 23@ == 1@
                803B: not 24@ == 2@
                    0229: set_car 31@ primary_color_to 1@ secondary_color_to 2@
            if 22@ == 8
                if or
                803B: not 23@ == 3@
                803B: not 24@ == 4@
                    0229: set_car 31@ primary_color_to 3@ secondary_color_to 4@
            if 22@ == 9
                if or
                803B: not 23@ == 5@
                803B: not 24@ == 6@
                    0229: set_car 31@ primary_color_to 5@ secondary_color_to 6@
            if 22@ == 10
                if or
                803B: not 23@ == 7@
                803B:not 24@ == 8@
                    0229: set_car 31@ primary_color_to 7@ secondary_color_to 8@
            if 22@ == 11
                if or
                803B:not 23@ == 9@
                803B:not 24@ == 10@
                    0229: set_car 31@ primary_color_to 9@ secondary_color_to 10@
            if 22@ == 12
                if or
                803B: not 23@ == 11@
                803B: not 24@ == 12@
                    0229: set_car 31@ primary_color_to 11@ secondary_color_to 12@
            if 22@ == 13
                if or
                803B: not 23@ == 13@
                803B: not 24@ == 14@
                    0229: set_car 31@ primary_color_to 13@ secondary_color_to 14@
            if 22@ == 14
                if or
                803B: not 23@ == 15@
                803B: not 24@ == 16@
                    0229: set_car 31@ primary_color_to 15@ secondary_color_to 16@
            if 22@ == 15
                if or
                803B: not 23@ == 17@
                803B: not 24@ == 18@
                    0229: set_car 31@ primary_color_to 17@ secondary_color_to 18@
            if 22@ == 16
                if or
                803B: not 23@ == 19@
                803B: not 24@ == 20@
                    0229: set_car 31@ primary_color_to 19@ secondary_color_to 20@
Download Link : GangsCC Customizer
Última edição por crspo2020 em Qui 03 Ago 2017, 01:59, editado 4 vez(es)
Título : Kick
Desde : 03/07/2015
em Qua 02 Ago 2017, 10:12
Mod updated fixed the bug that prevented the DaNangboys cars from getting colors due to a small mistake " getting float number instead of integer " .
Made more optimization to the script ,previously it would change the cars color no matter if it was already changed or not ... now it will check if the car was already changed or not before doing that... which results in the script very light weight ;)
Source available at the first post.
em Qua 02 Ago 2017, 23:58
Nice, but the source code is a bit confused, you put every if-statement inside another if-statement without necessity. So, I made small changes in the code structure and indentation:
{$cleo}
0000:
    1@ = -1
    2@ = -1
    3@ = -1
    4@ = -1
    5@ = -1
    6@ = -1
    7@ = -1
    8@ = -1
    9@ = -1
    10@ = -1
    11@ = -1
    12@ = -1
    13@ = -1
    14@ = -1
    15@ = -1
    16@ = -1
    17@ = -1
    18@ = -1
    19@ = -1
    20@ = -1
31@ : Car
21@ : Driver
22@ : pedtype
    29@ += 0x4
        000A: 29@ += 0x1
            0029: 31@ >= 0x00
            001B: 0x80 > 31@
            005A: 31@ += 30@
            jf continue
            if 22@ == 7
                if or
                803B: not 23@ == 1@
                803B: not 24@ == 2@
            if 22@ == 8
                if or
                803B: not 23@ == 3@
                803B: not 24@ == 4@
            if 22@ == 9
                if or
                803B: not 23@ == 5@
                803B: not 24@ == 6@
            if 22@ == 10
                if or
                803B: not 23@ == 7@
                803B:not 24@ == 8@
            if 22@ == 11
                if or
                803B:not 23@ == 9@
                803B:not 24@ == 10@
            if 22@ == 12
                if or
            if 22@ == 13
                if or
            if 22@ == 14
                if or
            if 22@ == 15
                if or
            if 22@ == 16
                if or
Edit: You can also put a "continue" after changing the car color.
Última edição por Nex' em Qui 03 Ago 2017, 02:11, editado 1 vez(es)
Título : Kick
Desde : 03/07/2015
em Qui 03 Ago 2017, 01:36
Oh yeah you are right , Thanks....... but you made a mistake  in this part , where is the if statement ? i know Sanny will compile it , but it's not clear for someone who reads the Source to learn.
  jf continue
Última edição por crspo2020 em Qui 03 Ago 2017, 01:52, editado 1 vez(es)
em Qui 03 Ago 2017, 01:51
crspo2020 escreveu:the IF statements inside each other didn't make a difference anyway.  (WINK)
An easy-to-understand source code is important, even if it makes no difference in the bytecode.
Edit:
crspo2020 escreveu:Oh yeah you are right , Thanks....... but you made a mistake  in this part , where is the if statement ?
  jf continue
Is the same as
if 856D: not actor 21@ defined
    continue
jf = jump in false
Última edição por Nex' em Qui 03 Ago 2017, 05:23, editado 1 vez(es)
em Qui 03 Ago 2017, 01:55
You can do it with any conditional opcode
Título : Kick
Desde : 03/07/2015
em Qui 03 Ago 2017, 01:58
i know Sanny will compile it , but it's not clear for someone who reads the Source to learn. i didn't even know that only jf  alone can do that until now  despite reading all the tutorials out there :V  ....... doesn't make a difference anyway  since   if   end  is more clear   than  jf
Also thanks for the tip , it will speed up my writing at some parts :D
em Qui 03 Ago 2017, 02:03
The first 3 spaces on the opcode description means this is a conditional opcode
01F3:  car $HJ_PLAYER_CAR in_air
0118:  actor 0@ dead
0AB0:  key_pressed 0x73
So it's easy to know that is a condition.
Título : Kick
Desde : 03/07/2015
em Qui 03 Ago 2017, 02:14
yeah i know that already  since it's mentioned in almost all cleo tutorials  :D   Thanks
em Qui 03 Ago 2017, 02:19
crspo2020 escreveu:yeah i know that already  since it's mentioned in almost all cleo tutorials  :D   Thanks
you're welcome :)
