[PRince4]
Título : Prem Bhai
Desde : 26/02/2018
Link : facebook.com/prince.sharma.3110
Ver perfil do usuáriohttps://facebook.com/prince.sharma.3110
em Ter 27 Mar 2018, 01:56
Yet, another Mind Boggling Bug i;m experiencing right now..
So about 2 or 3 days ago i Mipmapped My Downloaded "Rosa Project" and i tested it via modloader everything worked fine. (But the game started instantaneously closing in about every 5 mins but we'll deal with that later)
But when i Imported all the files via "IMG Mananger" with the option "Import Folder"  and Rebuilt the Archive i get this message after about half of the loading screen:
So i googled about Model with (ID 3991) so i found it was this :
So i checked those file in the .img :
My MODified "gta3.img" :
My Backup "gta3.img" :
And the Original "gta3.img" :
So you see all the files are there and identical, but why am i getting this?
and when i rename the "gta3.bak.img" to back to "gta3.img" game works just fine. So it means it started happening after i imported files into the gta3.img.
My Mipped textures works just fine with MODLoader and my Backup of "gta3.img" (Thank god i kept a backup).
Ba ek baar phir milpaon usse mei ...
em Ter 27 Mar 2018, 12:29
Error 0x00534134 is much more than "does not have loaded collision". Search for 0x00534134 in Crash List.
Detail: you're checking if is the same file by comparing KB, if it's for example 10 bytes different you will continue to think that is the same. And even if you look at each byte, it is still possible that a file is different — corrupted having the same size.
To check if files are different, use this:
But I think the problem isn't this file... But I don't know what can be, there are many possibilities, this crash is simply "could not load this object".
For you have an idea, one problem may simply be that you are open .img file. Just closing it fixes the problem.
[PRince4]
Título : Prem Bhai
Desde : 26/02/2018
em Ter 27 Mar 2018, 13:54
Yes, there is a difference in CRC of the files though, IDK why i didn't tried replacing them, But i'll See what it does..
@Junior_Djjr escreveu:one problem may simply be that you are open .img file. Just closing it fixes the problem.
I didn't get what you mean by that...
[PRince4]
Título : Prem Bhai
Desde : 26/02/2018
em Ter 27 Mar 2018, 14:05
Well NOPE!
I tried replacing the file from "original img" but nope it's the same...
I just don't get it.. My "GTA3.IMG" is now 4.90 GB is that have to do something with this?
I imported the file and rebuilt the archive but no profit....
And tried with the older img, works just fine...
em Ter 27 Mar 2018, 14:17
Well, but, you are showing the file lodgsfreeway7 and not gsfreeway7
Anyway, I don't know...
[PRince4]
Título : Prem Bhai
Desde : 26/02/2018
em Qua 28 Mar 2018, 04:29
@Junior_Djjr escreveu:Well, but, you are showing the file lodgsfreeway7 and not gsfreeway7
Ok, (I'm such a dumbo) , i didn't knew that i had to look for a ".col" so i guess i need to use MeD to find out where or what the ".col" file is...
em Qua 28 Mar 2018, 05:28
@[PRince4] escreveu:
lan_2.col
Should not be related to this either, but try.
This is a very early ID of the game objects, probably the error is in all objects and not only in this, lol. (i.e. if you fix the issue with 3991, the 3992 will fail... etc).
[PRince4]
Título : Prem Bhai
Desde : 26/02/2018
em Qua 28 Mar 2018, 13:45
@Junior_Djjr escreveu:lan_2.col
Yes, again you turned out right...
Now when i re-imported "lan_2.col" it now Said "Model ID 3999 Collision could not be loaded".
So, i just don't get it... How can just importing OK files Fuck-up the entire "gta3.img"?
I was importing because using Mipped Rosa Re-texture via MODLoader gives a instantaneous crash without and LOG. in about a Minute....
I check every log. (fastman92's limit adjuster's LOG, MODLoader's Log, MOONLoader's Log, SCRLog's Log and CLEO's Log).
em Qua 28 Mar 2018, 14:34
I think the problem was simply in creating .img. Try with another IMG Editor.
I think IMG Factory is the current best IMG editor, try it, or Alci's IMG Editor.
