TheGuinna
Desde : 30/03/2018
em Sab 31 Mar 2018, 12:04
Eu tava com o windows 10 no pc e nao estava gostando , entao ontem eu formatei pro 7 home basic e instalei os drives , mais o programa de drives dizia que tinha 7 desatualizados , entao atualizei , instalei o gta , coloquei o crqck certinho , mais quando inicio ele, simplismente nao sbre , ja fui no gerenciador de tarefas , ele aparece e some , como se tivesse finalizado o processo dele sozinho , ja tentei varias coisas , mais nao vai . o que pode ser?
em Sab 31 Mar 2018, 12:23
Apague o gta_sa.set da pasta GTA San Andreas User Files nos Documentos.
TheGuinna
Desde : 30/03/2018
em Sab 31 Mar 2018, 12:40
Nao tem o gta_sa.set pq o jogo nem inicia
Mystertv
Título : Estou te observando
em Sab 31 Mar 2018, 12:46
[PRince4]
Título : Prem Bhai
Desde : 26/02/2018
Link : facebook.com/prince.sharma.3110
Ver perfil do usuáriohttps://facebook.com/prince.sharma.3110
em Sab 31 Mar 2018, 14:02
Ok, instead of Starting a new thread i'm gonna post it here.
I'm experiencing the same bug, But it's really strange. it started about 3 days ago, IDK what happened after i came from work
and tried to run gta_sa.exe it gave me "Cleo : could not load plugin "newopcodes.cleo"" so i searched and searched and couldn't find any solution
on gta forums someone stated that i need to re-install VC++ 2010 so i did but it didn't worked. Then someone stated that removing the newopcodes.cleo can fix this but i need it for some mods
but i also tried removing it then modloader started to give crash.
And now that i'm trying to launch the  game it just stays in the background consuming like 200MBs only...
Also i would like to tell you guys that i noticed that all of my games settings were reset including Steam which also reverted to default settings.
IDK what happened my brother was using the Lap,  but he didn't said that anything like installing or uninstalling anything or even windows updating.
So all the other applications are working just as fine, but just what happened to gta?
I've modding my gta for like 4 years :(
EDIT :
i get this when i remove celo.asi :
GTA San Andreas não inicia  When_cleo
Log of fastman92's limit adjuster
Also i just remembered fastman92's limit adjuster again asked me for the donation window key which you have to put up on first startup of it.
Strange.
Ba ek baar phir milpaon usse mei ...
TheGuinna
Desde : 30/03/2018
em Sab 31 Mar 2018, 14:19
Infelismente nao funcionou , estou desistindo, muito obrigado
em Sab 31 Mar 2018, 14:23
@[PRince4] escreveu:But it's really strange. it started about 3 days ago, IDK what happened after i came from work
This error happens when you already have an open gta_sa.exe in the processes (even if only visible in the task manager) and you try to open another one.
[PRince4]
Título : Prem Bhai
Desde : 26/02/2018
em Dom 01 Abr 2018, 03:46
@Junior_Djjr escreveu:This error happens when you already have an open gta_sa.exe in the processes (even if only visible in the task manager) and you try to open another one.
I know about that and trust me, i made sure it wasn't open in the background process when i was trying to launch it.
Something probably happened in my Windows or some VC++ Redist fucked up.
I'm still searching for the problem btw do you know why did i get "CLEO : Could not plugin "newopcodes.cleo""?
em Dom 01 Abr 2018, 11:56
@[PRince4] escreveu:I'm still searching for the problem btw do you know why did i get "CLEO : Could not plugin "newopcodes.cleo""?
Nope, I only see this error being related to what I said.
TG4M3R
Desde : 30/03/2018
em Qua 04 Abr 2018, 13:43
@TheGuinna escreveu:Eu tava com o windows 10 no pc e nao estava gostando , entao ontem eu formatei pro 7 home basic e instalei os drives , mais o programa de drives dizia que tinha 7 desatualizados , entao atualizei , instalei o gta , coloquei o crqck certinho , mais quando inicio ele, simplismente nao sbre , ja fui no gerenciador de tarefas , ele aparece e some , como se tivesse finalizado o processo dele sozinho , ja tentei varias coisas , mais nao vai . o que pode ser?
Que tal vc ir em propriedades e alterar o modo de compatibilidade e alterar para modo de compatibilidade do Windows 98?
(se funcionar deixa a reputação ae! S2)
Dolan
[PRince4]
Título : Prem Bhai
Desde : 26/02/2018
em Sex 06 Abr 2018, 15:22
*TOPIC REVIVAL* [But please read :]
Holy Jesus Christ...
After about 3 weeks of me being a total dumb-ass i finally found why my GTA SA wasn't running (Was sleeping in the background).
Yes, it have been three weeks and i just fixed my gta_sa.exe, i bet you didn't know what and what i had to fix...
But actually there was nothing wrong with the gta or with my Windows... I kept fiddling with my Windows and VC++ Redists...
But let them stay at peace... So i just recently thought of finding the problem and tried removing almost all of the .dlls and .asi and .ini of MODs installed...
But it didn't fix it... Since the problem was... gta3.img...
So what was the problem in it? -> It was renamed to "gta3..img" and i just renamed it back to "gta3.img" and it worked....
I just can't believe i didn't even look in "Models" folder of gta... Well it's because i get about 2-3 hours of daily use thanks to my full time job... YUNO
The problem was just a full stop " . ".. yep just that...
*HUGE FACEPALM* que maravilha
and sorry for long post...
em Sex 06 Abr 2018, 17:44
@[PRince4] escreveu:"gta3..img" and i just renamed it back to "gta3.img" and it worked....
denilson gostoso denilson gostoso denilson gostoso
