DSTV_M4A1
DSTV_M4A1
Desde : 06/11/2012
Qui 17 Jul 2014, 20:30
So tem o tuning mod na modloader e crash quando aparece um carro
Antes que perguntem já tenho o crack hoodlum,cleo 4.3
mem fix e o san limiter tava na pasta ai tirei pq pensei que podia ser eles
========================== modloader 0.1.14 ==========================
Loading basic config file modloader/modloader.ini
Making sure directory "modloader/.data" exists...
Making sure directory "modloader/.data/plugins" exists...
Making sure directory "modloader/.data/cache" exists...
Reading command line
Done reading command line
Looking for plugins...
Reading plugins.ini
Loading plugin module 'std-asi.dll'
Plugin module 'std-asi.dll' loaded as std-asi 0.11 by LINK/2012
Loading plugin module 'std-bank.dll'
Plugin module 'std-bank.dll' loaded as std-bank 0.2 by LINK/2012
Loading plugin module 'std-cleo.dll'
Plugin module 'std-cleo.dll' loaded as std-cleo DC1 by LINK/2012
Loading plugin module 'std-data.dll'
Plugin module 'std-data.dll' loaded as std-data 0.3 by LINK/2012
Loading plugin module 'std-fx.dll'
Plugin module 'std-fx.dll' loaded as std-fx RC1 by LINK/2012
Loading plugin module 'std-img.dll'
Plugin module 'std-img.dll' loaded as std-img RC3 by LINK/2012
Loading plugin module 'std-movies.dll'
Plugin module 'std-movies.dll' loaded as std-movies RC1 by LINK/2012
Loading plugin module 'std-scm.dll'
Plugin module 'std-scm.dll' loaded as std-scm RC1 by LINK/2012
Loading plugin module 'std-sprites.dll'
Plugin module 'std-sprites.dll' loaded as std-sprites RC1 by LINK/2012
Loading plugin module 'std-text.dll'
Plugin module 'std-text.dll' loaded as std-text RC2 by LINK/2012
Starting up plugins...
Starting up plugin "std-bank"
Starting up plugin "std-asi"
Starting up plugin "std-cleo"
Finishing cache file
Nothing to finish
Starting up plugin "std-fx"
Starting up plugin "std-movies"
Starting up plugin "std-scm"
Starting up plugin "std-sprites"
Starting up plugin "std-text"
Starting up plugin "std-img"
Starting up plugin "std-data"
Creating data cache folder...
Looking for mods at "modloader\"...
Loading modloader config file modloader.ini
Reading mod "TuningMod\" (0) at "TuningMod\"...
Handler for file "CLEO\" (0) not found
Handler for file "CLEO\CLEO_TEXT\" (1) not found
Handler for file "CLEO\CLEO_TEXT\Tuning Mod.fxt" (2) is "std-text"
Handler for file "CLEO\IndieVehHandlings.cs" (3) is "std-asi"
Handler for file "CLEO\Tuning Mod\" (5) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\" (6) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\1.ini" (7) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\10.ini" (8) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\2.ini" (9) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\3.ini" (10) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\4.ini" (11) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\5.ini" (12) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\6.ini" (13) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\7.ini" (14) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\8.ini" (15) not found
Handler for file "CLEO\Tuning Mod\EXTRAS\9.ini" (16) not found
Handler for file "CLEO\Tuning Mod\Tuning Mod - VOL.ini" (17) not found
Handler for file "CLEO\Tuning Mod\turbo_1.mp3" (18) not found
Handler for file "CLEO\Tuning Mod\turbo_2.mp3" (19) not found
Handler for file "CLEO\Tuning Mod\turbo_3.mp3" (20) not found
Handler for file "CLEO\Tuning Mod\turbo_4.mp3" (21) not found
Handler for file "CLEO\Tuning Mod - Car Value.cs" (22) is "std-asi"
Handler for file "CLEO\Tuning Mod - POS.ini" (23) not found
Handler for file "CLEO\Tuning Mod Script1 (Junior_Djjr).cs" (24) is "std-asi"
Handler for file "CLEO\Tuning Mod Script2 (Junior_Djjr).cs" (25) is "std-asi"
Handler for file "CLEO\Tuning Mod.DJJR" (26) not found
Handler for file "gta3img\" (27) not found
Handler for file "gta3img\fighot.txd" (28) is "std-img"
Handler for file "gta3img\genintwarehsint3.txd" (29) is "std-img"
Handler for file "gta3img\smashtv.txd" (30) is "std-img"
Handler for file "Models\" (31) not found
Handler for file "Models\txd\" (32) not found
Handler for file "Models\txd\tuningm.txd" (33) is "std-sprites"
Handling files...
Pos processing...
Pos processing plugin "std-bank"
Pos processing plugin "std-asi"
CLEO library version 4030000 found at "CLEO.asi"
[CLEO] Module has been loaded: "CLEO.asi"
[CLEO] Module has been loaded: "cleo\FileSystemOperations.cleo"
[CLEO] Module has been loaded: "cleo\IniFiles.cleo"
[CLEO] Module has been loaded: "cleo\IntOperations.cleo"
Pos processing plugin "std-cleo"
Pos processing plugin "std-fx"
Pos processing plugin "std-movies"
Pos processing plugin "std-scm"
Pos processing plugin "std-sprites"
Pos processing plugin "std-text"
Injecting FXT file "modloader\TuningMod\CLEO\CLEO_TEXT\Tuning Mod.fxt"
Pos processing plugin "std-img"
Pos processing plugin "std-data"
Game is ready!
Loading fonts values "DATA\FONTS.DAT"
Splash screen events...
Reading readme file modloader\TuningMod\CLEO\IndieVehHandlings.txt
Done splash screen events.
Loading handling file "data/handling.cfg"
Loading time cycle "data/timecyc.dat"
Loading population cycle "data/popcycle.dat"
Load time events...
Done load time events.
Loading plant surface properties "data/plants.dat"
Loading level file "DATA\DEFAULT.DAT"
Loading object types file "DATA\DEFAULT.IDE "
Loading object types file "DATA\VEHICLES.IDE "
Loading object types file "DATA\PEDS.IDE "
Loading level file "DATA\GTA.DAT"
Opening level image file "DATA\PATHS\CARREC.IMG "
Opening level image file "DATA\SCRIPT\SCRIPT.IMG "
Opening level image file "MODELS\CUTSCENE.IMG "
Loading object types file "DATA\MAPS\generic\vegepart.IDE "
Loading object types file "DATA\MAPS\generic\barriers.IDE "
Loading object types file "DATA\MAPS\generic\dynamic.IDE "
Loading object types file "DATA\MAPS\generic\dynamic2.IDE "
Loading object types file "DATA\MAPS\generic\multiobj.IDE "
Loading object types file "DATA\MAPS\generic\procobj.IDE "
Loading object types file "DATA\MAPS\LA\LAn.IDE "
Loading object types file "DATA\MAPS\LA\LAn2.IDE "
Loading object types file "DATA\MAPS\LA\LAs.IDE "
Loading object types file "DATA\MAPS\LA\LAs2.IDE "
Loading object types file "DATA\MAPS\LA\LAe.IDE "
Loading object types file "DATA\MAPS\LA\LAe2.IDE "
Loading object types file "DATA\MAPS\LA\LAw2.IDE "
Loading object types file "DATA\MAPS\LA\LAw.IDE "
Loading object types file "DATA\MAPS\LA\LAwn.IDE "
Loading object types file "DATA\MAPS\LA\LAhills.IDE "
Loading object types file "DATA\MAPS\LA\LAxref.IDE "
Loading object types file "DATA\MAPS\SF\SFn.IDE "
Loading object types file "DATA\MAPS\SF\SFs.IDE "
Loading object types file "DATA\MAPS\SF\SFse.IDE "
Loading object types file "DATA\MAPS\SF\SFe.IDE "
Loading object types file "DATA\MAPS\SF\SFw.IDE "
Loading object types file "DATA\MAPS\SF\SFxref.IDE "
Loading object types file "DATA\MAPS\vegas\vegasN.IDE "
Loading object types file "DATA\MAPS\vegas\vegasS.IDE "
Loading object types file "DATA\MAPS\vegas\vegasE.IDE "
Loading object types file "DATA\MAPS\vegas\vegasW.IDE "
Loading object types file "DATA\MAPS\vegas\vegaxref.IDE "
Loading object types file "DATA\MAPS\country\countryN.IDE "
Loading object types file "DATA\MAPS\country\countN2.IDE "
Loading object types file "DATA\MAPS\country\countryS.IDE "
Loading object types file "DATA\MAPS\country\countryE.IDE "
Loading object types file "DATA\MAPS\country\countryW.IDE "
Loading object types file "DATA\MAPS\country\counxref.IDE "
Loading object types file "DATA\MAPS\interior\int_LA.IDE "
Loading object types file "DATA\MAPS\interior\int_SF.IDE "
Loading object types file "DATA\MAPS\interior\int_veg.IDE "
Loading object types file "DATA\MAPS\interior\int_cont.IDE "
Loading object types file "DATA\MAPS\leveldes\levelmap.IDE "
Loading object types file "DATA\MAPS\leveldes\levelxre.IDE "
Loading object types file "DATA\MAPS\interior\gen_int1.IDE "
Loading object types file "DATA\MAPS\interior\gen_int2.IDE "
Loading object types file "DATA\MAPS\interior\gen_intb.IDE "
Loading object types file "DATA\MAPS\interior\gen_int3.IDE "
Loading object types file "DATA\MAPS\interior\gen_int4.IDE "
Loading object types file "DATA\MAPS\interior\gen_int5.IDE "
Loading object types file "DATA\MAPS\interior\savehous.IDE "
Loading object types file "DATA\MAPS\interior\stadint.IDE "
Loading object types file "DATA\MAPS\leveldes\seabed.IDE "
Loading object types file "DATA\MAPS\interior\props.IDE "
Loading object types file "DATA\MAPS\interior\props2.IDE "
Loading object types file "DATA\MAPS\interior\propext.IDE "
Loading object types file "DATA\MAPS\veh_mods\veh_mods.IDE "
Loading object types file "DATA\TXDCUT.IDE "
Loading vehicle upgrades file "DATA\CARMODS.DAT"
Importing model file for index 22655 at "modloader\TuningMod\gta3img\smashtv.txd"
Importing model file for index 20820 at "modloader\TuningMod\gta3img\fighot.txd"
Importing model file for index 22646 at "modloader\TuningMod\gta3img\genintwarehsint3.txd"
Abstract cd directory has been loaded
Loading scene file "DATA\MAP.ZON "
Loading scene file "DATA\INFO.ZON "
Loading scene file "DATA\MAPS\LA\LAn.IPL "
Loading scene file "DATA\MAPS\LA\LAn2.IPL "
Loading scene file "DATA\MAPS\LA\LAs.IPL "
Loading scene file "DATA\MAPS\LA\LAs2.IPL "
Loading scene file "DATA\MAPS\LA\LAe.IPL "
Loading scene file "DATA\MAPS\LA\LAe2.IPL "
Loading scene file "DATA\MAPS\LA\LAw.IPL "
Loading scene file "DATA\MAPS\LA\LAwn.IPL "
Loading scene file "DATA\MAPS\LA\LAw2.IPL "
Loading scene file "DATA\MAPS\LA\LAhills.IPL "
Loading scene file "DATA\MAPS\SF\SFn.IPL "
Loading scene file "DATA\MAPS\SF\SFs.IPL "
Loading scene file "DATA\MAPS\SF\SFse.IPL "
Loading scene file "DATA\MAPS\SF\SFe.IPL "
Loading scene file "DATA\MAPS\SF\SFw.IPL "
Loading scene file "DATA\MAPS\vegas\vegasN.IPL "
Loading scene file "DATA\MAPS\vegas\vegasS.IPL "
Loading scene file "DATA\MAPS\vegas\vegasE.IPL "
Loading scene file "DATA\MAPS\vegas\vegasW.IPL "
Loading scene file "DATA\MAPS\country\countryN.IPL "
Loading scene file "DATA\MAPS\country\countN2.IPL "
Loading scene file "DATA\MAPS\country\countrys.IPL "
Loading scene file "DATA\MAPS\country\countryE.IPL "
Loading scene file "DATA\MAPS\country\countryW.IPL "
Loading scene file "DATA\MAPS\interior\int_LA.IPL "
Loading scene file "DATA\MAPS\interior\int_SF.IPL "
Loading scene file "DATA\MAPS\interior\int_veg.IPL "
Loading scene file "DATA\MAPS\interior\int_cont.IPL "
Loading scene file "DATA\MAPS\interior\gen_int1.IPL "
Loading scene file "DATA\MAPS\interior\gen_int2.IPL "
Loading scene file "DATA\MAPS\interior\gen_intb.IPL "
Loading scene file "DATA\MAPS\interior\gen_int3.IPL "
Loading scene file "DATA\MAPS\interior\gen_int4.IPL "
Loading scene file "DATA\MAPS\interior\gen_int5.IPL "
Loading scene file "DATA\MAPS\interior\stadint.IPL "
Loading scene file "DATA\MAPS\interior\savehous.IPL "
Loading scene file "DATA\MAPS\leveldes\levelmap.IPL "
Loading scene file "DATA\MAPS\leveldes\seabed.IPL "
Loading scene file "DATA\MAPS\paths.ipl "
Loading scene file "DATA\MAPS\paths2.ipl "
Loading scene file "DATA\MAPS\paths3.ipl "
Loading scene file "DATA\MAPS\paths4.ipl "
Loading scene file "DATA\MAPS\paths5.ipl "
Loading scene file "DATA\MAPS\cull.ipl "
Loading scene file "DATA\MAPS\tunnels.ipl "
Loading scene file "DATA\MAPS\occluSF.ipl "
Loading scene file "DATA\MAPS\occluveg.ipl "
Loading scene file "DATA\MAPS\occluLA.ipl "
Loading scene file "DATA\MAPS\occluint.ipl "
Loading scene file "DATA\MAPS\audiozon.ipl "
Loading train tracks "data\paths\tracks.dat"
Loading train tracks "data\paths\tracks3.dat"
Loading train tracks "data\paths\tracks2.dat"
Loading train tracks "data\paths\tracks4.dat"
Loading water level "DATA\water.dat"
Starting injected cleo script search 0a0cb448 for version '0'...
Injecting extra scripts into search 0a0cb448...
Injecting cleo script "modloader\TuningMod\CLEO\IndieVehHandlings.cs"
Injecting cleo script "modloader\TuningMod\CLEO\Tuning Mod - Car Value.cs"
Injecting cleo script "modloader\TuningMod\CLEO\Tuning Mod Script1 (Junior_Djjr).cs"
Injecting cleo script "modloader\TuningMod\CLEO\Tuning Mod Script2 (Junior_Djjr).cs"
Finishing injected cleo script search 0a0cb448...
Starting injected cleo script search 0a0cb568 for version '4'...
Finishing injected cleo script search 0a0cb568...
Starting injected cleo script search 0a0cb4a8 for version '3'...
Finishing injected cleo script search 0a0cb4a8...
Reload time events...
Done reload time events.
Starting injected cleo script search 0a0cb608 for version '0'...
Injecting extra scripts into search 0a0cb608...
Finishing injected cleo script search 0a0cb608...
Starting injected cleo script search 0a0cb668 for version '3'...
Finishing injected cleo script search 0a0cb668...
Starting injected cleo script search 0a0cb5c8 for version '0'...
Injecting extra scripts into search 0a0cb5c8...
Finishing injected cleo script search 0a0cb5c8...
Starting injected cleo script search 0a0cb588 for version '4'...
Finishing injected cleo script search 0a0cb588...
Unhandled exception at 0x0e64578b in "???": 0xC0000005: Access violation DEP at 0x0e64578b.
Calling loader.Shutdown();
Shutting down modloader...
Unloading plugin "std-bank"
Unloading plugin "std-asi"
Unloading plugin "std-cleo"
Unloading plugin "std-fx"
Unloading plugin "std-movies"
Unloading plugin "std-scm"
Unloading plugin "std-sprites"
Unloading plugin "std-text"
Unloading plugin "std-img"
Unloading plugin "std-data"
Deleting data cache folder...
modloader has been shutdown.
> Logging finished: 20:19:37
  Powered by sa-modloader (https://github.com/thelink2012/sa-modloader)
Qui 17 Jul 2014, 20:57
...e na pasta CLEO normal dá certo?
Tuning mod na Mod Loader 2ywzqdu
Elyzandro
Elyzandro
Qui 17 Jul 2014, 22:01
@LINK/2012 escreveu:...e na pasta CLEO normal dá certo?
Não sei porque, mas comigo não funciona NENHUM mod cleo no ModLoader  ohgodwhy
DSTV_M4A1
DSTV_M4A1
Desde : 06/11/2012
Qui 17 Jul 2014, 22:35
Vish deu a mesma coisa, agora complico meu gta ta limpo so tem cleo ea modloader nem tem nada na cleo, oque pode ser  T_T
Qui 17 Jul 2014, 23:22
Acho que o problema está no ini carregado pelo Tuning Mod
Tuning mod na Mod Loader 226c0ef57f9d7520d171cbadc68b3c56
Tuning mod na Mod Loader 76561198069372249
DSTV_M4A1
DSTV_M4A1
Desde : 06/11/2012
Sex 18 Jul 2014, 00:17
@Fabio escreveu:Acho que o problema está no ini carregado pelo Tuning Mod
lol baixei na mix tem ate um link alternativo com um exe mais baxei pelo copy
Sex 18 Jul 2014, 15:42
@DSTV_M4A1 escreveu:lol baixei na mix tem ate um link alternativo com um exe mais baxei pelo copy
WAT, COMO ASSIM .EXE???
...Fabio, LINK/2012 botou a possibilidade de poder usar cleos com ini etc no modloader, soh ter a pasta com nome "cleo" e os ini etc dentro
e... sobre o problema com seu gta... eh pq vc nao leu e seguiu as dicas do FAQ
