Baixei hoje a versão 0.2.1 do Modloader mas quando abro o GTA o jogo para de funcionar!
Obs: Já tirei TODOS os mods que eu tenho instalado aqui (deixando apenas o modloader) e mesmo assim não funcionou...
manda o modloader/modloader.log man.
@LINK/2012 escreveu:manda o modloader/modloader.log man.
- modloader.log:
- ========================== Mod Loader 0.2.1 ==========================
Game version: GTA SA 1.0 US
Parsing command line
Menu disabled, not injecting one
Looking for plugins...
Failed to read plugins.ini
Plugin module "gta3\std.asi.dll" loaded as gta3.std.asi Nov 23 2014 21:10:55 by LINK/2012
CLEO library version 4030000 found at "CLEO.asi"
Plugin module "gta3\std.bank.dll" loaded as gta3.std.bank Nov 23 2014 21:10:37 by LINK/2012
Plugin module "gta3\std.fx.dll" loaded as gta3.std.fx Nov 23 2014 21:10:29 by LINK/2012
Plugin module "gta3\std.movies.dll" loaded as gta3.std.movies Nov 23 2014 21:10:24 by LINK/2012
Plugin module "gta3\std.scm.dll" loaded as gta3.std.scm Nov 23 2014 21:10:25 by LINK/2012
Plugin module "gta3\std.sprites.dll" loaded as gta3.std.sprites Nov 23 2014 21:10:27 by LINK/2012
Plugin module "gta3\std.stream.dll" loaded as gta3.std.stream Nov 23 2014 21:10:46 by LINK/2012
Plugin module "gta3\std.text.dll" loaded as gta3.std.text Nov 23 2014 21:10:33 by LINK/2012
Mod Loader has started up!
Unhandled exception at 0x00826723 in gta_sa.exe (+0x426723): 0xC0000005: Access violation writing location 0x00000000.
Register dump:
EAX: 0x0913A268 EBX: 0x00000000 ECX: 0x00000084 EDX: 0x00000000
EDI: 0x00000000 ESI: 0x0913A058 EBP: 0x0022FB8C EIP: 0x00826723
ESP: 0x0022FB84 EFL: 0x00010212 CS: 0x0000001B SS: 0x00000023
GS: 0x00000000 FS: 0x0000003B ES: 0x00000023 DS: 0x00000023
Stack dump:
0x0022FB84: 008E2CB0 00000210 0022FBB4 0082349C 00000000 0913A058
0x0022FB9C: 00000210 00B71852 00000001 00000001 FFFFFFE8 00001000
0x0022FBB4: 0022FBF4 0082354B FFFFFFE8 00000001 FFFFFFE8 008E2CB0
0x0022FBCC: 00000001 00B71852 00000001 00000001 0022FBCC 0022F790
0x0022FBE4: 0022FC8C 00825EA4 00887F50 00000000 0022FC1C 00538966
0x0022FBFC: 00000000 00000001 FFFFFFE8 008E2CB0 63032574 008E2CB0
0x0022FC14: 00000000 FFFFFFE8 0022FC38 63032B3B 0022FC34 0022FC40
0x0022FC2C: 0022FC44 0022FC48 00538950 008E2CB0 005B4EF9 008E2CB0
0x0022FC44: 00BC40D8 FFFFFFE8 008E2CB0 0022FC74 00000018 008E2C90
0x0022FC5C: 00B71852 00000000 036623D0 00000001 00000000 00000000
base: 0x00030000 top: 0x0022FB84 bottom: 0x00230000
Backtrace:
=>0x00826723 in gta_sa.exe (+0x426723) (0x0022FB8C)
0x0082349C in gta_sa.exe (+0x42349c) (0x0022FBB4)
0x0082354B in gta_sa.exe (+0x42354b) (0x0022FBF4)
0x00538966 in gta_sa.exe (+0x138966) (0x0022FC1C)
0x63032B3B in std.stream.dll (+0x2b3b) (0x0022FC38)
0x005B4EF9 in gta_sa.exe (+0x1b4ef9) (0x0022FC8C)
0x0083D4FB in gta_sa.exe (+0x43d4fb) (0x0022FF88)
0x75A8EE1C BaseThreadInitThunk+0x12 in kernel32.dll (+0x4ee1c) (0x0022FFD4)
0x771B37BE RtlInitializeExceptionChain+0xc2 in ntdll.dll (+0x637be) (0x0022FFD8)
0x00824570 in gta_sa.exe (+0x424570) (0x0022FFDC)
0x7FFDF000 in unknown (+0x7ffdf000) (0x0022FFE0)
Shutting down Mod Loader...
Mod Loader has been shutdown.
Shutting down menu...
to dando uma analisada aqui, ja dou uma resposta
Substitui isso aqui na pasta modloader/.data/plugins/gta3
https://dl.dropboxusercontent.com/u/35476123/std.stream.zip
O problema deve arrumar, mas acaba desabilita uma feature do Mod Loader (o que não é legal), então é necessario arrumar esse problema de uma forma efetiva. Tem algum serviço que possamos se comunicar mais rapido (Facebook, Skype, etc)?
Skype: thif98 (baixando agora pois formatei meu PC semana passada)
