vi agr no wikipedia
mas msm assim ainda fica aquela duvida... como diabos isso se forma tao bem assim? @__@ pq ali eh assim e logo dobra e vira assim e fica assim e ali na ponta fica assim e assim? bem loco imaginar
ainda mais q os desenhos sao super variados
http://en.wikipedia.org/wiki/SnowflakeIn warmer clouds an aerosol particle or "ice nucleus" must be present in (or in contact with) the droplet to act as a nucleus. The particles that make ice nuclei are very rare compared to nuclei upon which liquid cloud droplets form; however, it is not understood what makes them efficient. Clays, desert dust and biological particles may be effective,[3] although to what extent is unclear. Artificial nuclei include particles of silver iodide and dry ice, and these are used to stimulate precipitation in cloud seeding.[4]
Once a droplet has frozen, it grows in the supersaturated environment, which is one where air is saturated with respect to ice when the temperature is below the freezing point. The droplet then grows by deposition of water molecules in the air (vapor) onto the ice crystal surface where they are collected. Because water droplets are so much more numerous than the ice crystals due to their sheer abundance, the crystals are able to grow to hundreds of micrometers or millimeters in size at the expense of the water droplets. This process is known as the Wegener–Bergeron–Findeisen process. The corresponding depletion of water vapor causes the droplets to evaporate, meaning that the ice crystals grow at the droplets' expense. These large crystals are an efficient source of precipitation, since they fall through the atmosphere due to their mass, and may collide and stick together in clusters, or aggregates. These aggregates are usually the type of ice particle that falls to the ground.[5] Guinness World Records list the world's largest (aggregate) snowflakes as those of January 1887 at Fort Keogh, Montana; allegedly one measured 15 inches (38 cm) wide. Although this report by a farmer is doubtful, aggregates of three or four inches width have been observed. Single crystals the size of a dime have been observed.[1]
The exact details of the sticking mechanism remain controversial. Possibilities include mechanical interlocking, sintering, electrostatic attraction as well as the existence of a "sticky" liquid-like layer on the crystal surface. The individual ice crystals often have hexagonal symmetry. Although the ice is clear, scattering of light by the crystal facets and hollows/imperfections mean that the crystals often appear white in color due to diffuse reflection of the whole spectrum of light by the small ice particles.[6] The shape of the snowflake is determined broadly by the temperature and humidity at which it is formed.[5] Rarely, at a temperature of around −2 °C (28 °F), snowflakes can form in threefold symmetry — triangular snowflakes.[7] The most common snow particles are visibly irregular, although near-perfect snowflakes may be more common in pictures because they are more visually appealing. It is unlikely that any two snowflakes are alike due to the estimated 1019 (10 quintillion) water molecules which make up a typical snowflake,[8] which grow at different rates and in different patterns depending on the changing temperature and humidity within the atmosphere that the snowflake falls through on its way to the ground
^^^ é obvio que é natural. Somos capazes de ver e reconhecer. Padrões naturais são repetitivos e não inteligíveis.
e quanto a isso? é natural ou fruto de uma mente inteligente?
Não se sabe o nome do autor
___________________________________________________________________
flagelo bacteriano: formação natural ou produto de uma mente inteligente?
- motor rotação variável de 12000 rpm
- inversão de rotação em milésimos de segundos
- buchas de conteção
- eletricidade
- rotor
- E muito mais. É um verdadeiro motor complexo.
Leia isso e se impressione com o design óbvio desse motor biológico (tradução livre):
Dr. Howard Berg [Univ.Harvard], o maior especialista na dinâmica de Praga, disse:
' É uma extraordinariamente pequeno motor elétrico que roda "com um eixo de acionamento, rotor, estator, rolamentos, junta universal, placa de montagem e mudar de montagem. Funciona com prótons de energia do motor ou íons de sódio através da membrana celular por canais especializados. Responde a gradientes químicos com maior volume de negócios. "A cargas elevadas são ativos oito ou mais geradores de força, cada um gerando o mesmo par." Cerca de 20 partes de proteínas são a base do motor, mas em muitas outras partes adicionais estão envolvidos durante a montagem. O motor é construído dentro para fora, com as peças a ser adicionado na sequência de uma seqüência estrita ... '
Professor Berg fez um pouco de cálculo para saber a quantidade de energia gerada pelo motor. Se ele ser estendido para nossa escala diz, seria de cerca de 11 cavalos de potência / kg, aproximadamente, gerado por uma aeronave turboélice ". Mas, ao contrário disso, o flagelo não é aquecida, "Este motor é refrigerado a água e difusão térmica é muito eficiente em pequenas distâncias, para que ele permaneça perto de temperatura ambiente."
Ou seja, ele reconhece é um sistema de servo único, que identificou a presença de 20 proteínas que estabelecem as suas peças ... construídas de dentro para fora, na sequência de um programa, como o único caminho possível para fazê-lo.
Eu não vou colocar aqui todos encontrados dentro do flagelo, porque o artigo é muito alongar, mas eu quero salientar que incluiu uma semelhança com anticorpos fator que bloqueia a expressão de genes posteriores responsáveis pela "codificar" as sequências proteicas filamentosa FliC, o Mot A e proteínas B, e os vários componentes da rota quimiotáxico ... Finalmente decidiu entrar para um defensor genética evolutiva!
O que o Dr. Berg disse, nada menos, é que este motor é construído seguindo as instruções genéticas listados e codificados no DNA da bactéria. E agora a cauda do peixe: se a informação codificada, não podemos dizer que surgiu através da evolução, uma vez que por poderosas que querem fazer, a seleção natural é apenas algo de estar virtual em certos conceitos, sem qualquer manifestação física provável ... incapaz de codificar instruções. Uma fonte afirma que o encoder externo agente, indica dedução e inteligência.
This is it, the code. Essa img do floco ai me fez lembrar de um programa chamado the code.
Fiquei assistindo dai o cara tbm falou sobre essas pedras com formato hexagonal formadas naturalmente por lava vulcânica em contato com a água, só pesquisar por calçada dos gigantes se quiserem ver mais imgs, tem outros nomes tbm mas esse é o mais comum.
Quem ja jogou a dlc dragonborn do skyrim vai lembrar delas.
- Hardware :
- Monitor AOC VGA 19,5" LED 1366x768 / TV Samsung HDMI 42" LED 1920x1080
RAM: Kingston Dual-Channel 4096 MB 8GB (utilizável 7,68GB) 1333Mhz DDR3
SSD: 120GB Sandstone
HD: 2TB
HD Externo: WD 2TB
Fonte: EVGA 500W 80plus
OS: Windows 10 64bits
Mas são bonitos
- Hardware :
HD: 2TB
HD Externo: WD 2TB
sim. E bem curiosos :)
Eu não vejo como uma criança pode virar adulto em um piscar de olhos.
Tudo o que o homem cria é para um propósito, afinal, sem propósito, não teria motivo para fazer tal coisa. Agora, me diga, qual o propósito da vida? Pois a Terra pode muito bem ficar sem vida.
não somos capazes de responder essa pergunta.
Precisamos viver e descobrir por si próprio: O que farei de minha vida? Acho que esse é o propósito.
Estou falando literalmente. A vida não precisa existir para que o universo exista.
o conceito de existência é filosófico. Para vc definir existência é preciso que vc exista.
- albertoos360Mensagens Nível 5
Desde : 03/11/2014
eu vi um documentario muito legal sobre o mundo sem humanos
como a terra ia ficar,é muito bom este documentario recomendo a todos a assistir.
Tirando o conceito filosófico (pois filosofia só existe por causa de nós), a vida não tem propósito.@Hue escreveu:o conceito de existência é filosófico. Para vc definir existência é preciso que vc exista.
Acredito em vida alienígena. Se a própria Via Lactea ainda não foi totalmente explorada imagina as outras milhares de galáxias universo à fora.
Desde : 03/11/2014
sim a grande change de existir vida la fóra só precisa ter as condiçoes para que a vida exista.
acredito que exista vida microscópica em outros planetas.
- 3xt3rm1n4d0rVeterano
Reputação : 17
Desde : 10/01/2014
As condições que precisam ser atendidas para que vivamos podem não ser as mesmas para outros seres então né
Desde : 03/11/2014
isso mesmo cada forma de vida tem suas condiçoes.@3xt3rm1n4d0r escreveu:As condições que precisam ser atendidas para que vivamos podem não ser as mesmas para outros seres então né
Esse fórum tá todo fodido.
Desde : 03/11/2014
foi voce que criou thelost.
Tchau.
@Thelost escreveu: a vida não tem propósito.
Não diga isso
parece um suicida falando ;-;
Que tal criar um tópico para falar sobre filosofia?
- ElyzandroVeterano
eu tbm acho q a vida nao tem propósito
mas tipo, nao específico, basicamente o propósito eh vc quem cria... mas um propósito geral da vida em si nao, somos um bando de inúteis q soh estão aqui por estar
acho impossível tudo isso por nada, sem propósito.
"impossível" eh demais nao acha?
Velho, pode matar o mundo, pode sumir a Terra. O universo vai continuar.
