BomBomBum
BomBomBum
Desde : 14/05/2015
Link : steamcommunity.com/id/H-3D/
Qui 14 Maio 2015, 12:44
Ola para qualquer scripter que esta vendo esse tópico, estava tentando fazer com que o mod Back to the Future funcionase no meu GTA, mas mesmo esse mod sendo cleo 3 e eu instalando cleo 3 num GTA limpo o mod continua sem funcionar e são só dois scripts que estão dando erros.
speed.cs (velocimetro):
// This file was decompiled using sascm.ini published by Seemann (http://sannybuilder.com/files/SASCM.rar) on 13.10.2007
{$VERSION 3.1.0027}
thread "SPDMTR"
1@ = 255
2@ = 50
3@ = 50
6@ = 1
:Speed
   wait 10
       Player.Defined($PLAYER_CHAR)
   jf continue
       Actor.Driving($PLAYER_ACTOR)
   jf continue
   // Is player time travelling?
   0AB4: 5@ = var 0
       not 5@ == 1
   jf continue
   // Enables/disables speedometer
       32@ > 500
       0AB0:  key_pressed 0xDB // '['
       6@ *= -1
       6@ += 1
       32@ = 0
   // If speedometer is enabled, draw speedometer
       6@ == 1
   jf continue
   03C0: 0@ = actor $PLAYER_ACTOR car
   02E3: 4@ = car 0@ speed
   4@ *= 2.236936
   008C: 4@ = float 4@ to_integer
   gosub @Draw
   033F: set_text_draw_letter_size 2.0 8.0
   03E4: enable_text_draw_align_right 1
   // Pads output with zeroes if < 10
       4@ > 9
       045A: draw_text_1number 600.0 375.0 GXT "SPEED" number 4@
   else
       045A: draw_text_1number 600.0 375.0 GXT "SPEED1" number 4@
//----------------Functions----------------//
:Draw
0340: set_text_draw_RGBA 1@ 2@ 3@ 255
0341: unknown_text_draw_flag 1
03E4: enable_text_draw_align_right 0
0343: set_text_draw_linewidth 5000.0
0348: enable_text_draw_proportional 1
0342: enable_text_draw_centered 0
0345: enable_text_draw_background 0
033F: set_text_draw_letter_size 0.5 1.8
return
keypad.cs (digitar hora, dia, ano, mês, etc):
{$VERSION 3.1.0027}
thread 'INPUT'
1@ = 0
2@ = 0
3@ = 0
4@ = 0
5@ = 0
6@ = 1
0AAC: 7@ = load_mp3 "CLEO\AUDIO\INPUT_ON.MP3"
0AAC: 8@ = load_mp3 "CLEO\AUDIO\INPUT_OFF.MP3"
0AAC: 9@ = load_mp3 "CLEO\AUDIO\INPUT_ENTER.MP3"
0AAC: 20@ = load_mp3 "CLEO\AUDIO\0.MP3"
0AAC: 21@ = load_mp3 "CLEO\AUDIO\1.MP3"
0AAC: 22@ = load_mp3 "CLEO\AUDIO\2.MP3"
0AAC: 23@ = load_mp3 "CLEO\AUDIO\3.MP3"
0AAC: 24@ = load_mp3 "CLEO\AUDIO\4.MP3"
0AAC: 25@ = load_mp3 "CLEO\AUDIO\5.MP3"
0AAC: 26@ = load_mp3 "CLEO\AUDIO\6.MP3"
0AAC: 27@ = load_mp3 "CLEO\AUDIO\7.MP3"
0AAC: 28@ = load_mp3 "CLEO\AUDIO\8.MP3"
0AAC: 29@ = load_mp3 "CLEO\AUDIO\9.MP3"
:Keypad
   wait 10
   jf continue
   // checks to see if car is not wrecked and player is inside
   0AB4: 30@ = var 8
      not Car.Wrecked(30@)
   jf continue
      Actor.InCar($PLAYER_ACTOR, 30@)
   jf continue
   // Wait until user is not time travelling
   repeat
       wait 10
       0AB4: 0@ = var 0
   until 0@ == 0
   0AB4: 0@ = var 1
   // is time circuit switch pressed?
   if or
       0AB0:   key_pressed 0x6B // 'KP+'
       0AB0:   key_pressed 0xBB // '='
       // play appropriate sound and turn on/off time circuits
         0@ == 0
           0AB3: var 1 = 1
           0AAD: set_mp3 7@ perform_action 0
           0AAD: set_mp3 7@ perform_action 1
           wait 1000
       else
           0AB3: var 1 = 0
           0AAD: set_mp3 8@ perform_action 0
           0AAD: set_mp3 8@ perform_action 1
           wait 500
   // Checks to see if time circuits are on
     0@ == 1
   jf continue
   // Sees if a number key is pressed
   5@ = 0x30
   for 5@ = 0x30 to 0x39 step 1
           0AB0: key_pressed 5@
           0085: 4@ = 5@ // (int)
           4@ -= 0x30
           gosub @KeypadNumPressed
   for 5@ = 0x60 to 0x69 step 1
           4@ -= 0x60
   // checks to see if confirm key is pressed
   if or
       0AB0:   key_pressed 0x6D // 'KP-'
       0AB0:   key_pressed 0xBD // '-'
   jf continue
   // checks input buffer length
   if or
       3@ == 4
       3@ == 8
       3@ == 12
           3@ == 4
           0085: 11@ = 1@ // (int)
           gosub @KeypadHM
       else if
           3@ == 8
           0085: 10@ = 1@ // (int)
           gosub @KeypadMDY
       else
           0085: 11@ = 2@ // (int)
           gosub @KeypadMDY
           gosub @KeypadHM
           6@ == 1
           gosub @KeyConfirmPressedSound
       else
           gosub @KeyErrorSound
   else
   // Reset
   wait 100
   1@ = 0
   2@ = 0
   3@ = 0
   6@ = 1
:KeypadMDY
// Separates MDY
0085: 12@ = 10@
0AB1: call_scm_func @Mod 2 12@ 10000 14@
12@ /= 10000
0AB1: call_scm_func @Mod 2 12@ 100 13@
12@ /= 100
// Keeps same time if input is 8 digits long
   3@ == 8
   0AB4: 11@ = var 4
// Error on invalid ranges
if or
   12@ == 0
   13@ == 0
   12@ > 12
   6@ = 0
else
   // checks day ranges based on months
   // leap year
       12@ == 2
       0085: 17@ = 14@ // (int)
       0085: 18@ = 14@ // (int)
       0085: 19@ = 14@ // (int)
       17@ /= 400
       17@ *= 400
       18@ /= 100
       18@ *= 100
       19@ /= 4
       19@ *= 4
           803B:   not  14@ == 18@ // (int)
           003B:   14@ == 19@ // (int)
             13@ > 29
             6@ = 0
       else
               003B:   14@ == 17@ // (int)
                 13@ > 29
                 6@ = 0
           else
                 13@ > 28
                 6@ = 0
   else
       if or
         12@ == 4
         12@ == 6
         12@ == 9
         12@ == 11
             13@ > 30
             6@ = 0
       else
             13@ > 31
             6@ = 0
return
:KeypadHM
// continue if no errors from calculating month, day, and year
 6@ == 1
   0085: 12@ = 11@
   12@ /= 100
   // keeps same date if input is 4 digits long
     3@ == 4
       0AB4: 10@ = var 3
   // Errors on invalid ranges
   if or
     12@ > 23
     13@ > 59
     6@ = 0
return
:KeypadNumPressed
// play sound
 4@ == 0
   0AAD: set_mp3 20@ perform_action 0
   0AAD: set_mp3 20@ perform_action 1
else if
   4@ == 1
   0AAD: set_mp3 21@ perform_action 0
   0AAD: set_mp3 21@ perform_action 1
else if
   4@ == 2
   0AAD: set_mp3 22@ perform_action 0
   0AAD: set_mp3 22@ perform_action 1
else if
   4@ == 3
   0AAD: set_mp3 23@ perform_action 0
   0AAD: set_mp3 23@ perform_action 1
else if
   4@ == 4
   0AAD: set_mp3 24@ perform_action 0
   0AAD: set_mp3 24@ perform_action 1
else if
   4@ == 5
   0AAD: set_mp3 25@ perform_action 0
   0AAD: set_mp3 25@ perform_action 1
else if
   4@ == 6
   0AAD: set_mp3 26@ perform_action 0
   0AAD: set_mp3 26@ perform_action 1
else if
   4@ == 7
   0AAD: set_mp3 27@ perform_action 0
   0AAD: set_mp3 27@ perform_action 1
else if
   4@ == 8
   0AAD: set_mp3 28@ perform_action 0
   0AAD: set_mp3 28@ perform_action 1
else if
   4@ == 9
   0AAD: set_mp3 29@ perform_action 0
   0AAD: set_mp3 29@ perform_action 1
else
   return
// adds number to 2 input buffers, max size of 8 each
  3@ < 8
 1@ *= 10
 005A: 1@ += 4@ // (int)
else
 2@ *= 10
 005A: 2@ += 4@
//ignores anything over 12 digits long
 3@ <= 12
 3@ += 1
// waits until user lets go of key
while 0AB0:   key_pressed 5@
   wait 10
return
//Enter sound
:KeyConfirmPressedSound
0AB3: var 10 = 2
0AB3: var 3 = 10@   //year
0AB3: var 4 = 11@   //hour
0AAD: set_mp3 9@ perform_action 0
0AAD: set_mp3 9@ perform_action 1
wait 450
0AB3: var 10 = 1
wait 100
0AB3: var 10 = 0
wait 450
return
//Error Sound
:KeyErrorSound
return
:Mod
0085: 2@ = 0@ // (int)
0072: 2@ /= 1@ // (int)
006A: 2@ *= 1@ // (int)
0062: 0@ -= 2@ // (int)
0AB2: ret 1 0@
Esses dois scripts, assim que são ativados fazem aparecer umas linhas pretas uma por cima da outra e logo após trava o jogo, principalmente o keypad.cs que trava na hora.
Desculpa o post meio noob, mas é nescessario pq ta dificil aqui pra esse mod funcionar e ainda mais que eu to com preguiça de ficar colocando link aqui um atras do outro :)
-sim sou novo- espero não perder o tempo de vcs  okay
Última edição por BomBomBum em Qui 14 Maio 2015, 12:52, editado 2 vez(es) (Razão : Estou tendo erros com esse mod e gostaria muito mas muito jogar com ele)
I'MAH MLG PRO:
Uma musica legal e bacana em :)   :)
PawnBy
PawnBy
Desde : 01/09/2014
Qui 14 Maio 2015, 13:40
https://brmodstudio.forumeiros.com/t4714-mods-crasham-sem-motivo
Algo parecido com isso? não vai pegar cara, esses mods porcarias foi feito na gambiarra por isso não funcionam direito... e por isso não conseguiram achar o problema desse topico que passei :)
BomBomBum
BomBomBum
Desde : 14/05/2015
Qui 14 Maio 2015, 13:56
Cara vou explicar aqui do pq eu passar só esses dois scripts e não o resto:
com o speed.cs na pasta cleo (isso na cleo 4 pq cleo 3 nem mostra o mapa) eu entro num veiculo e 1 segundo dps começa a aparecer umas linhas pretas no meio da tela e o jogo crasha, mas com o keypad ou timecircuits (não sei qual dos dois ta com erro) aparece umas linhas pretas no canto e ja da crash na hora, as vezes fala que é main.scm que deu crash e as vezes fala que foi num .cs.
e quando eu tiro o speed.cs o jogo funciona de boas, tirando a parte onde eu ativo o mod pra digitar o tempo que eu gostaria de ir pokerface
não manjo de cleo mas pelo que sei são mais esses dois que fazem bugar mas
I'MAH MLG PRO:
Qui 14 Maio 2015, 16:58
@PawnBy escreveu:não vai pegar cara, esses mods porcarias foi feito na gambiarra por isso não funcionam direito...
primeiro q gambiarra nao quer dizer q nao funciona direito
segundo q eu nao achei tao porcaria, principalmente o keypad, parece fodinha o script
uma coisa estranha, eh q usaram draw...... mas nao tiraram da tela serious? como q funcionaria entao? wat, se vc nao tira a textura da tela ela vai ficar lah, e no proximo frame aparece outra e outra, até q numa hora chega a 127 e crasha o jogo pq bateu o limite
eu nao acho q isso corrigiria o seu problema, deve ser outro, msm assim, dae o script com essa correção:
{$VERSION 3.1.0027}
thread "SPDMTR"
1@ = 255
2@ = 50
3@ = 50
6@ = 1
:Speed
  wait 10
  jf continue
  jf continue
  0AB4: 5@ = var 0
      not 5@ == 1
  jf continue
      32@ > 500
      6@ *= -1
      6@ += 1
      32@ = 0
      6@ == 1
  jf continue
  4@ *= 2.236936
  gosub @Draw
      4@ > 9
  else
  03F0: enable_text_draw 1
:Draw
return
BomBomBum
BomBomBum
Desde : 14/05/2015
Qui 14 Maio 2015, 21:44
Thanks! Vou compilar pro meu gta e testar, amanha te respondo se deu certo ou não. :)
I'MAH MLG PRO:
BomBomBum
BomBomBum
Desde : 14/05/2015
Qui 14 Maio 2015, 22:25
JR uma pergunta rapida, o que tu fez pra esse script funcionar dnv?
ao que parece tem outro com o mesmo problema se quiser eu posto um link pro script
I'MAH MLG PRO:
Qui 14 Maio 2015, 22:27
Ele colocou essa linha:
Qui 14 Maio 2015, 22:39
coloca essa linha abaixo de algum "draw_text"
soh uma linha e pronto
BomBomBum
BomBomBum
Desde : 14/05/2015
Qui 14 Maio 2015, 22:41
Acho melhor dar umas estudada melhor em cleo argh
Mas tem mais um script com pubrema aquie foreveralone
http://pastebin.com/d4hBqJ0d   :)
Bem agradeço pela ajuda de vcs aquie comigo e se der do uma postada no mod com essas correções pro cleo 4
EDIT: Desculpa n tinha atualizado a pag, vlw ae pessoal e principalmente o JR amos seus mods e tu brigadaun somuchwin
I'MAH MLG PRO:
Qui 14 Maio 2015, 22:52
Esquece CLEO 3, não tem porquê usar ela.
Qui 14 Maio 2015, 23:38
eu nao toh entendendo pq ele tah falando de cleo 3 e cleo 4 aqui
PawnBy
PawnBy
Desde : 01/09/2014
Sex 15 Maio 2015, 02:38
Nex' escreveu:Esquece CLEO 3, não tem porquê usar ela.
Meu numero da sorte, não vou parar de usar a 3 até sair a 6 ... 3+3=6 Sorte em dobro serious? trollface
Claudio
Claudio
Desde : 25/12/2014
Sex 15 Maio 2015, 11:58
Cleo 6 nunca vai existir, no maximo a cleo 5, gta sa e um jogo bem limitado.
Sex 15 Maio 2015, 18:54
Claudio Velocidade escreveu:no maximo a cleo 5, gta sa e um jogo bem limitado.
acho q vc nao sabe ao certo oq eh uma "cleo"
Sex 15 Maio 2015, 19:19
Claudio Velocidade escreveu:Cleo 6 nunca vai existir, no maximo a cleo 5, gta sa e um jogo bem limitado.
E o que a quantidade de versões da livraria CLEO tem a ver com o gta ser limitado ou não?
pokerface
Sex 15 Maio 2015, 19:51
explicando oq eh uma cleo:
cleo eh uma biblioteca de novos opcodes (codigos de operação)
um exemplo de opcode simples adicionado na cleo 3:
0A8E: 0@ = 1@ + 2@
na cleo 2 ou 1 ou antes da cleo, vc tinha q fazer assim:
005A: 1@ += 2@
0085: 0@ = 1@
portanto, aquele opcode adicionado na cleo 3 economiza 1 linha e deixa o script mais levígel
dae tem outros opcodes mais complexos, como tocar algum som (onde ele usa a bass.dll, uma dll super comum q vários programas atuais tbm usam ela, nao tem nada a ver com limites do gta)
ou aqueles opcodes q evitam vc ler endereços de memoria
por exemplo:
esse opcode:
010B: 0@ = player $PLAYER_CHAR money
evita vc ter q ler o endereço de memória 0xB7CE50, eh muito mais prático
dae vc tem uma infinidade (literalmente) de novos opcodes, pode criar até a cleo 100 q ainda continuará tendo ideias de opcodes... por exemplo nas novas cleos podem vir opcodes q trocam o tipo de pedestre sem necessitar manusear memórias, ou até msm trocar texturas de modelos usando texturas .png numa pasta (assim como o newopcodes.cleo), limite nao eh problema, dah pra fazer de tudo
Sex 15 Maio 2015, 19:58
0A8E: 0@ = 1@ + 2@
Por algum motivo na escola eu tava pensando se dava pra fazer isso invés de
005A: 1@ += 2@
0085: 0@ = 1@
:v:
Tem muitas coisas simples que poderiam adicionar também pra facilitar, não lembro exemplos agora mas quando comecei a mexer com cleo toda hora me perguntava
"Porque não tem opcode pra isso? porra..."
Sex 15 Maio 2015, 20:40
sim
de cara ai vc jah está vendo outro exemplo
nesse opcode q te mostrei agr soh soma valores inteiros e nao pontos flutuantes.... nao há opcode pra pontos flutuantes ainda... pq? ue, seria útil
na cleo 5 (ou uma nova versão do sanny builder q simule essa gambiarra) podeira ter como fazer contas diretas numa soh linha (Fabio tbm sempre quis isso, acho q todos nós queremos)
0@ = 1@ / 2.0 + 0.1
vei, isso seria ÓTIMO, todas as programações de verdade têm isso
Sex 15 Maio 2015, 21:08
Sim, ficar fazendo isso em um monte de linha é um saco ;_;
Sab 16 Maio 2015, 09:42
E não é muito difícil fazer um leitor de expressões matemáticas, o sanny builder provavelmente não tem isso por preguiça do criador mesmo ;-;
[MOD ANTIGO!!] BTTF Mod error 226c0ef57f9d7520d171cbadc68b3c56
[MOD ANTIGO!!] BTTF Mod error 76561198069372249
