Sten
Sten
Desde : 06/02/2017
Seg 06 Fev 2017, 21:43
Quando abro meu Gta San Andreas antes de carregar crasha.
log: scrlog
script noname
Local variables dump:
5805 5805
00000000&0: [0002] GOTO 43808
00043808&0: [0002] GOTO 53156
00053156&0: [0002] GOTO 53720
00053720&0: [0002] GOTO 55948
00055948&0: [0002] GOTO 55960
00055960&0: [0002] GOTO 55976
00055976&0: [03A4] SCRIPT_NAME "MAIN"
00055987&0: [016A] DO_FADE 0 0
00055993&0: [042C] SET_TOTAL_NUMBER_OF_MISSIONS 147
00055998&0: [030D] SET_PROGRESS_TOTAL 187
00056003&0: [0997] SET_MISSION_RESPECT_TOTAL 1339
00056008&0: [01F0] SET_MAX_WANTED_LEVEL 6
00056012&0: [0111] SET_DEATHARREST_STATE 0
00056016&0: [00C0] SET_TIME_OF_DAY 8 0
00056022&0: [04E4] REQUEST_COLLISION 2488.56 -1666.86
00056034&0: [03CB] LOAD_SCENE 2488.56 -1666.86 13.3757
00056051&0: [062A] SET_FLOAT_STAT 165 800.0
00056061&0: [062A] SET_FLOAT_STAT 23 50.0
00056070&0: [062A] SET_FLOAT_STAT 21 200.0
00056079&0: [062A] SET_FLOAT_STAT 160 0.0
00056089&0: [0629] SET_INT_STAT 181 0
00056096&0: [0629] SET_INT_STAT 68 0
00056102&0: [0053] CREATE_PLAYER 0 2488.56 -1666.86 12.8757 -> 0
00056124&0: [0002] GOTO 56153
00056153&0: [06CF] COMMAND_06CF 0
00056157&0: [0746] SET_RELATIONSHIP 1 8 0
00056165&0: [0746] SET_RELATIONSHIP 4 8 7
00056173&0: [0746] SET_RELATIONSHIP 3 8 9
00056181&0: [0746] SET_RELATIONSHIP 3 8 14
00056189&0: [0746] SET_RELATIONSHIP 3 7 0
00056197&0: [0746] SET_RELATIONSHIP 4 7 8
00056205&0: [0746] SET_RELATIONSHIP 3 7 9
00056213&0: [0746] SET_RELATIONSHIP 3 7 14
00056221&0: [0746] SET_RELATIONSHIP 3 9 0
00056229&0: [0746] SET_RELATIONSHIP 3 9 8
00056237&0: [0746] SET_RELATIONSHIP 3 9 7
00056245&0: [0746] SET_RELATIONSHIP 4 9 14
00056253&0: [0746] SET_RELATIONSHIP 3 14 0
00056261&0: [0746] SET_RELATIONSHIP 3 14 8
00056269&0: [0746] SET_RELATIONSHIP 3 14 7
00056277&0: [0746] SET_RELATIONSHIP 4 14 9
00056285&0: [0746] SET_RELATIONSHIP 3 10 11
00056293&0: [0746] SET_RELATIONSHIP 3 10 13
00056301&0: [0746] SET_RELATIONSHIP 3 11 10
00056309&0: [0746] SET_RELATIONSHIP 3 13 10
00056317&0: [0746] SET_RELATIONSHIP 4 13 11
00056325&0: [0746] SET_RELATIONSHIP 4 11 13
00056333&0: [07AF] GET_PLAYER_GROUP 0 -> 65536
00056341&0: [01F5] GET_PLAYER_CHAR 0 -> 1
00056349&0: [0373] SET_CAMERA_BEHIND_PLAYER
00056351&0: [0173] SET_CHAR_HEADING 1 262.0
00056361&0: [0417] LOAD_AND_LAUNCH_MISSION 0
00056365&0: [0001] WAIT 0
script Vehicle
1094924493 1330604799
00000000&0: [03A4] SCRIPT_NAME "VEHSPWN"
00000011&0: [0006] l5(0) = 441
00000019&0: [0006] l30(0) = 2
00000026&0: [0001] WAIT 0
script Tuning
537535469 538982093
00000000&0: [03A4] SCRIPT_NAME "TM_tire"
00000011&0: [00D6] IF 21
00000015&0: [8AF0] NOT READ_INT_FROM_INI_FILE "cleo\Tuning Mod\Tuning Mod - CFG.ini" "CONFG" "TireWear" -> 1    // FALSE
00000075&0: [0039] l0(1) == 0    // FALSE
00000082&0: [004D] GOTO_IF_FALSE -91
00000091&0: [0050] GOSUB -3092
00003092&0: [0AC6] GET_LABEL_POINTER -3440 -> 48613096
00003102&0: [000E] l0(48613096) -= 7086501
00003112&0: [0A8C] WRITE_MEMORY 0x6C21A0 1 232 1
00003126&0: [0A8C] WRITE_MEMORY 0x6C21A1 4 41526595 1
00003140&0: [0A8C] WRITE_MEMORY 0x6C21A5 1 144 1
00003154&0: [0A8C] WRITE_MEMORY 0x6C21A6 1 144 1
00003168&0: [0A8C] WRITE_MEMORY 0x6C21A7 1 144 1
00003182&0: [0A8D] READ_MEMORY 0x5BFA96 4 1 -> 12761544
00003196&0: [000A] l17(12761544) += 20
00003203&0: [0A8D] READ_MEMORY 0xC2B9DC 4 0 -> 0
00003215&0: [00D6] IF 0
00003219&0: [0039] l2(0) == -1    // FALSE
00003226&0: [004D] GOTO_IF_FALSE -3339
00003339&0: [00D6] IF 0
00003343&0: [0039] l17(12761564) == 12761564    // TRUE
00003353&1: [004D] GOTO_IF_FALSE -3390
00003360&1: [0A8D] READ_MEMORY 0x6F531E 4 1 -> 50004
00003374&1: [005A] l26(50004) += l17(12761564)
00003382&1: [0006] l14(0) = 224
00003390&1: [0AC6] GET_LABEL_POINTER -3440 -> 48613096
00003400&1: [000A] l0(48613096) += 23
00003407&1: [0A8C] WRITE_MEMORY 0x2E5C6FF 4 12761564 0
00003419&1: [000A] l0(48613119) += 8
00003426&1: [0A8C] WRITE_MEMORY 0x2E5C707 4 12811568 0
00003438&1: [0051] RETURN
00000098&1: [0001] WAIT 0
script Tuning
977555182 1077496013
00000000&0: [0A95] SAVE_THIS_CUSTOM_SCRIPT
00000002&0: [04CE] COMMAND_04CE 1636.14 -1524.86 13.122 27 -> 131072
00000024&0: [04CE] COMMAND_04CE -2534.91 -18.89 15.9427 27 -> 131073
00000046&0: [04CE] COMMAND_04CE 1606.76 728.564 10.8761 27 -> 131074
00000068&0: [04CE] COMMAND_04CE 1667.74 1080.46 10.5 27 -> 131075
00000090&0: [04CE] COMMAND_04CE -1763.39 1472.34 0.0 27 -> 131076
00000112&0: [04CE] COMMAND_04CE 1602.68 1619.47 11.0 27 -> 131077
00000134&0: [04CE] COMMAND_04CE -1969.01 -2433.94 32.5 27 -> 131078
00000156&0: [0A93] TERMINATE_THIS_CUSTOM_SCRIPT
script Tuning
168638157 538982093
00000000&0: [03A4] SCRIPT_NAME "TM_Djjr"
00000011&0: [0001] WAIT 0
script Traffic
808340193 1111976141
00000000&0: [03A4] SCRIPT_NAME "TRAFFIC_"
00000019&0: [0000] NOP
00000021&0: [0006] l0(0) = 0
00000028&0: [0006] l1(0) = 0
00000035&0: [0006] l2(0) = 0
00000042&0: [0006] l3(0) = 0
00000049&0: [0006] l4(0) = 0
00000056&0: [0006] l5(0) = 0
00000063&0: [0006] l6(0) = 0
00000070&0: [0006] l7(0) = 0
00000077&0: [0006] l8(0) = 0
00000084&0: [0007] l9(0.0) = 0.0
00000094&0: [0006] l10(0) = 0
00000101&0: [0006] l11(0) = 0
00000108&0: [0006] l12(0) = 0
00000115&0: [0006] l13(0) = 0
00000122&0: [0006] l14(0) = 0
00000129&0: [0006] l15(0) = 0
00000136&0: [0007] l16(0.0) = 0.0
00000146&0: [0007] l17(0.0) = 0.0
00000156&0: [0007] l18(0.0) = 0.0
00000166&0: [0007] l19(0.0) = 0.0
00000176&0: [0007] l20(0.0) = 0.0
00000186&0: [0007] l21(0.0) = 0.0
00000196&0: [0007] l22(0.0) = 0.0
00000206&0: [0007] l23(0.0) = 0.0
00000216&0: [0007] l24(0.0) = 0.0
00000226&0: [0007] l25(0.0) = 0.0
00000236&0: [0007] l26(0.0) = 0.0
00000246&0: [0006] l27(0) = 0
00000253&0: [0007] l28(0.0) = 0.0
00000263&0: [0006] l29(0) = 0
00000270&0: [0006] l30(0) = 0
00000277&0: [0007] l31(0.0) = 0.0
00000287&0: [0006] l32(808340193) = 0
00000294&0: [0006] l33(1111976141) = 0
00000301&0: [0001] WAIT 1000
script THIEF_A
1095915508 604003316
00000000&0: [03A4] SCRIPT_NAME "MAFIAII"
script Telepor
1763730939 1495283375
00000000&0: [03A4] SCRIPT_NAME "TPIN"
00000011&0: [0006] l5(0) = 0
00000018&0: [0001] WAIT 0
script tapete.
-2147477837 7405
00000000&0: [03A4] SCRIPT_NAME "POLICIA_"
00000020&0: [20D6] COMMAND_20D6
> Logging finished: 21:37:00
Foto para identificar melhor o crash  https://plus.google.com/photos/photo/114632886713305489123/6384144573348700882?icm=false&authkey=CKens-nb8f6I4AE
Rafael_Antunes
Rafael_Antunes
Desde : 16/11/2016
Seg 06 Fev 2017, 21:49
Deve estar faltando o NewOpcodes CLEO no seu GTA SA baixe e veja se o Crash ainda acontece : https://drive.google.com/file/d/0B1sAJQAUfOOYckxKaVZ4NjZJa1U/view
[CRASH] GTA SA Me ajudem! RVNEjyB
Mak47
Mak47
Seg 06 Fev 2017, 21:57
vc tem alguem mod que é relacionado a policia?
Sten
Sten
Desde : 06/02/2017
Seg 06 Fev 2017, 22:00
Police Assistance.cs
Sten
Sten
Desde : 06/02/2017
Seg 06 Fev 2017, 22:04
@Rafael_Antunes escreveu:Deve estar faltando o NewOpcodes CLEO no seu GTA SA baixe e veja se o Crash ainda acontece : https://drive.google.com/file/d/0B1sAJQAUfOOYckxKaVZ4NjZJa1U/view
Já baixei e ainda acontece
Rafael_Antunes
Rafael_Antunes
Desde : 16/11/2016
Seg 06 Fev 2017, 22:05
Então não sei =/
Abduzydo
Abduzydo
Desde : 12/06/2015
Idade : 32
Seg 06 Fev 2017, 22:58
script tapete.
-2147477837 7405
EDIT: porra na propria print q vc tiro ta mandando "não tirar prints" e sim enviar o arquivo .log e pra finalizar seria o .log do modloader e não o do FLA
Nimb><><Èris        caos...        Lyssa S2 Loki
Kaoss em Lagunia
Sten
Sten
Desde : 06/02/2017
Sab 11 Fev 2017, 18:28
Gente consegui resolver obrigado a todos.
Rafael_Antunes
Rafael_Antunes
Desde : 16/11/2016
Sab 11 Fev 2017, 18:31
@Sten escreveu:Gente consegui resolver obrigado a todos.
Blz só que da proxima vez manda o .log do modloader e não o Scrlog e o .log do FLA
