MS
MS
Designer - Básico
Designer - Básico
Nick anterior : msb165
Reputação : 60
Desde : 26/02/2017
Qua 01 Mar 2017, 23:23
========================== Mod Loader 0.3.5 ==========================
Game version: GTA SA 1.0 US
Parsing command line
Loaded fallback menu fxt
Looking for plugins...
Reading plugins.ini
Plugin module "gta3\std.asi.dll" loaded as gta3.std.asi Nov 12 2016 18:52:33 by LINK/2012
Plugin module "gta3\std.bank.dll" loaded as gta3.std.bank Nov 12 2016 18:52:34 by LINK/2012
Plugin module "gta3\std.data.dll" loaded as gta3.std.data Nov 12 2016 18:52:35 by LINK/2012
Plugin module "gta3\std.fx.dll" loaded as gta3.std.fx Nov 12 2016 18:52:38 by LINK/2012
Plugin module "gta3\std.movies.dll" loaded as gta3.std.movies Nov 12 2016 18:52:50 by LINK/2012
Plugin module "gta3\std.scm.dll" loaded as gta3.std.scm Nov 12 2016 18:53:09 by LINK/2012
Plugin module "gta3\std.sprites.dll" loaded as gta3.std.sprites Nov 12 2016 18:53:10 by LINK/2012
Plugin module "gta3\std.stream.dll" loaded as gta3.std.stream Nov 12 2016 18:52:34 by LINK/2012
Plugin module "gta3\std.text.dll" loaded as gta3.std.text Nov 12 2016 18:52:34 by LINK/2012
Plugin module "gta3\std.tracks.dll" loaded as gta3.std.tracks Nov 12 2016 18:52:33 by LINK/2012
Mod Loader has started up!
Unhandled exception at 0x047EF0B3 in d3d9.dll (+0x1f0b3): 0xC0000005: Access violation reading location 0x00000000.
Register dump:
EAX: 0x05100048 EBX: 0x00000000 ECX: 0x00000000 EDX: 0x0194FFB0
EDI: 0x047D8130 ESI: 0x00000000 EBP: 0x0028F844 EIP: 0x047EF0B3
ESP: 0x0028F7D8 EFL: 0x00210206 CS: 0x00000023 SS: 0x0000002B
GS: 0x0000002B FS: 0x00000053 ES: 0x0000002B DS: 0x0000002B
Stack dump:
0x0028F7D8: 00C9C040 047D8153 047D8130 00C9C040 0028F844 00000000
0x0028F7F0: 0194FFB0 0028F7CC 00000000 0028F998 708DAC73 2FAB3F05
0x0028F808: FFFFFFFE 708CE871 708CF0A4 7091DCB0 017B2FD0 007F99B0
0x0028F820: 0028F844 7091DCCD 7091DCF4 05100048 00C9C040 03DE74F8
0x0028F838: 007F99B0 00000000 00000000 7640FCF5 007F9A21 05100048
0x0028F850: 00C9C040 03DE74F8 007F99B0 00000000 007FB1C3 03DE74F8
0x0028F868: 00060528 00000001 00000001 03DE43C4 007EE388 03DE74F8
0x0028F880: 00060528 00000001 00000000 0074526A 03DE43C4 00060528
0x0028F898: 00000001 00590902 03DE43C4 03DE43C4 00000001 00000000
0x0028F8B0: 00748ABB 00000001 00000001 00000001 00000000 00000001
base: 0x00090000 top: 0x0028F7D8 bottom: 0x00290000
Backtrace (may be wrong):
=>0x047EF0B3 Direct3DCreate9+0x17363 in d3d9.dll (+0x1f0b3) (0x0028F844)
0x007F9A21 in gta_sa.exe (+0x3f9a21) (0x0028F85C)
0x007FB1C3 in gta_sa.exe (+0x3fb1c3)
Shutting down Mod Loader...
Shutting down menu...
Mod Loader has been shutdown.
Rafael_Antunes
Rafael_Antunes
Desde : 16/11/2016
Qua 01 Mar 2017, 23:53
Não faço ideia doq seja,e o endereço não esta na lista de crash philosoraptor instalou o mod da maneira correta ? Já viu se seu PC roda ?
GTA SA Crashando com MMGE RVNEjyB
MS
MS
Designer - Básico
Designer - Básico
Reputação : 60
Desde : 26/02/2017
Qui 02 Mar 2017, 00:04
@Rafael_Antunes escreveu:Não faço ideia doq seja,e o endereço não esta na lista de crash philosoraptor instalou o mod da maneira correta ? Já viu se seu PC roda ?
instalei como mandava o leiame, e sim, meu pc roda :)
Rafael_Antunes
Rafael_Antunes
Desde : 16/11/2016
Qui 02 Mar 2017, 00:45
Pode estar faltando algo no seu PC
http://www.mixmods.com.br/2015/08/download-baixar-dll-microsoft-visual-directx9.html
baixe o "DirectX End-User Web Installer" (o primeiro desse link) que talvez resolva
E baixe o "Microsoft .NET Framework 4.5.2" (o ultimo do link) que vai funcionar eu acho
Qui 02 Mar 2017, 00:56
O erro é com o d3d9.dll, explicação para o erro da lista de crash:
Erro: d3d9.dll
Tipo: Crash
Problema 1: Como você já deve saber, é a .dll usada para várias coisas, principalmente enb series, então tudo define em para O QUE você usou ela (onde 99% das pessoas usam ela como enb series ou já veio na instalação do jogo). Pode ser que seu PC não suporte a enb series ou outro mod gráfico que use essa dll, mas também há mods que são feitos usando esta dll, mods super antigos lá do lançamento do GTA SA na qual acabaram usando esta .dll para criar o mod, coisa totalmente obsoleta agora, deixe de usar tais mods. Caso você não use enb series ou outros mods desta dll, deve ser corrigível atualizando seu DirectX Runtime, e logo em seguida, caso tenha esta dll instalada no seu jogo, deletá-la (ou não).
Problema 2: Caso crashou numa missão, estranhamente pode dar o crash nesta dll e a solução enviada pelo Luiz Felipe diz que simplesmente você tem que pular a cutscene apertando Enter. Pode ser causado por alguma legenda bugada ou outro texto na tela, geralmente por traduções ou mods, neste caso, é melhor contatar o criador e/ou desativar as legendas ou pular a cutscene se possível. A tradução da Gamevicio tem este crash, a nossa tradução pt-br não.
Problema 3: Caso crash no menu Advanced dos gráficos do jogo e você esteja usando 90s AVP Reborn, foi causado pelo Super GT dele e a solução é simplesmente trocar este carro. Do mesmo modo que você pode não estar usando o 90s AVP mas estar com este mesmo carro, ou outro carro com o mesmo problema, ou seja, caso crash nesta dll neste menu, pode ser algum carro instalado no seu GTA.
Problema 4: Durante alguma explosão? Usando algum mod como Remastered Effects? Caso tiver algum 0x007FDE14 e/ou 0x007FE7DC e/ou 0x004A140A no "Backtrace" no fim do log, pode ser que seja causado pelo IgnoreWater do MixSets (ou até mesmo FreezeHour). Assim, se tiver ativado, configure estas funções para -1 no MixSets.
http://www.mixmods.com.br/p/lista-de-crash-e-solucoes.html
Perkzitos
Perkzitos
Desde : 18/02/2017
Qui 02 Mar 2017, 15:13
Talvez sua placa de vídeo seja shader 2.5?
Que merda em pokerface
MS
MS
Designer - Básico
Designer - Básico
Reputação : 60
Desde : 26/02/2017
Qui 02 Mar 2017, 16:39
@Perkzitos escreveu:Talvez sua placa de vídeo seja shader 2.5?
Não, a minha placa é uma GTX 660
Rafael_Antunes
Rafael_Antunes
Desde : 16/11/2016
Qui 02 Mar 2017, 18:09
msb165 escreveu:
Ele não que saber qual é a placa mas qula é o Shader dela ?
MS
MS
Designer - Básico
Designer - Básico
Reputação : 60
Desde : 26/02/2017
Qui 02 Mar 2017, 21:56
msb165 escreveu:
Shader 5.0
Qui 02 Mar 2017, 22:11
msb165 escreveu:
Aqui também não rodou, acabei perdendo a vontade e nem tentei procurar a solução do problema.
GTA SA Crashando com MMGE 226c0ef57f9d7520d171cbadc68b3c56
GTA SA Crashando com MMGE 76561198069372249
MS
MS
Designer - Básico
Designer - Básico
Reputação : 60
Desde : 26/02/2017
Qui 02 Mar 2017, 22:29
msb165 escreveu:
Eu lembro que eu consegui fazer funcionar uma vez, não lembro como..
Sex 03 Mar 2017, 05:50
Nem disse qual MMGE
MS
MS
Designer - Básico
Designer - Básico
Reputação : 60
Desde : 26/02/2017
Sex 03 Mar 2017, 10:57
@Junior_Djjr escreveu:Nem disse qual MMGE
Todos os mmge não funcionam, até a enb original v 306 não pega, só crasha....
Sex 03 Mar 2017, 11:33
msb165 escreveu:
Então é incompatibilidade com seu PC. Fim.
MS
MS
Designer - Básico
Designer - Básico
Reputação : 60
Desde : 26/02/2017
Sex 03 Mar 2017, 12:32
msb165 escreveu:
Não, então como ela funcionou antes? por que só agora ela não funciona?
Sex 03 Mar 2017, 13:41
msb165 escreveu:
msb165 escreveu:
Formatou o PC dentro deste tempo? (no mínimo alguma troca de Windows)
MS
MS
Designer - Básico
Designer - Básico
Reputação : 60
Desde : 26/02/2017
Sex 03 Mar 2017, 14:24
msb165 escreveu:
msb165 escreveu:
Eu cheguei a fazer uma troca de um windows sim...
Sex 03 Mar 2017, 14:31
Dá para tentar instalar o SDK do DirectX. philosoraptor
Rafael_Antunes
Rafael_Antunes
Desde : 16/11/2016
Sex 03 Mar 2017, 18:21
O cara podia falar qual o Win dele pra (tipo o 10) pra ver se ele fez aquela instalação pra Windows mais novos (ou algo assim)
Sex 03 Mar 2017, 18:27
É foda quando não dizem detalhes :v:
Tipo ele disse que fez uma troca de Windows, blz, mas se por exemplo trocou pro Windows 8~10 faz sentido dar o problema, pois é necessário fazer uns troços extras na instalação.
Rafael_Antunes
Rafael_Antunes
Desde : 16/11/2016
Sex 03 Mar 2017, 18:38
Pse
É tipo "Ah ta crashando com a ENB Series MMGE ta ai o log do modloader,resolvam ai pra mim"
MS
MS
Designer - Básico
Designer - Básico
Reputação : 60
Desde : 26/02/2017
Sex 03 Mar 2017, 20:40
@Rafael_Antunes escreveu:Pse
Desculpe, é que vocês demoram pra responder, mas ok, eu troquei pra o windows 8(eu ja estava com ele só que eu troquei por outro ja pronto) e não lembro exatamente se funcionava ou não anteriormente...
Rafael_Antunes
Rafael_Antunes
Desde : 16/11/2016
Sex 03 Mar 2017, 21:10
Tem que fazer uns negocio na instalação do mod então (acho que esse Windows 8 conta) só agora esqueci oq tem que fazer I Like Trains talvez o Junior responda
MS
MS
Designer - Básico
Designer - Básico
Reputação : 60
Desde : 26/02/2017
Sab 04 Mar 2017, 12:02
@Rafael_Antunes escreveu:Tem que fazer uns negocio na instalação do mod então (acho que esse Windows 8 conta) só agora esqueci oq tem que fazer I Like Trains talvez o Junior responda
Deixa pra lá, descobri uma solução, renomeie o exe pra qualquer outro nome, que funciona Raisins Face
Renato
Renato
Título : Título
Desde : 05/02/2016
Sab 04 Mar 2017, 12:46
msb165 escreveu:Deixa pra lá, descobri uma solução, renomeie o exe pra qualquer outro nome, que funciona  Raisins Face
serious? Acho que é uma das soluções mais WTF que eu já vi.
GTA SA Crashando com MMGE DJZ6D83
