- Thiago FilhoMensagens Nível 1
Desde : 30/10/2017
O crash ocorre na missão Drive-Thru, quando o CJ volta pra grove após matar os Ballas. Quando me aproximo da Grove ou passo de certo ponto, o jogo crasha. Já procurei esse crash e não achei em lugar algum. O último código do scrlog é o 0001, então não irei postá-lo.
- MODLOADER.LOG:
- ========================== Mod Loader 0.3.6 ==========================
Loaded fallback menu fxtGame version: GTA SA 1.0 US
Unhandled exception at 0x0040C229 in gta_sa.exe (+0xc229): 0xC0000005: Access violation reading location 0x00000002.
Register dump:
EAX: 0x00000001 EBX: 0x01A349B4 ECX: 0xFF71B340 EDX: 0xFFF8E290
EDI: 0x00000000 ESI: 0x00000000 EBP: 0x0028F804 EIP: 0x0040C229
ESP: 0x0028F7CC EFL: 0x00010296 CS: 0x00000023 SS: 0x0000002B
GS: 0x0000002B FS: 0x00000053 ES: 0x0000002B DS: 0x0000002B
Stack dump:
0x0028F7CC: 00000000 0000006B 0053BF10 0028F824 0028F898 01A349B4
0x0028F7E4: 47158000 0028F804 0FF41E04 0053E986 0028F80C 77A3E023
0x0028F7FC: 03A82A80 00000001 0028F81C 03A7E213 0028F84C 0028F85C
0x0028F814: 03AD213E 00000000 0028F868 03A83CCF 03AE3CAC 01A36C00
0x0028F82C: 019C7618 019C7688 019C7618 00000001 09AF2B28 0028F854
0x0028F844: 0028F820 0028F824 00000001 01A36C00 01A349A0 0028F994
0x0028F85C: 0028F884 03AD3ABE FFFFFFFF 0028F874 03A838C1 0028F824
0x0028F874: 0028F890 03A80E67 0028F898 0028F994 0028F980 03AD213E
0x0028F88C: 00000000 0028F98C 03A802C3 03AE3C74 01A36C00 0028F994
0x0028F8A4: 00000000 00000000 01A36C00 0028F980 03AD360B 00000003
base: 0x00090000 top: 0x0028F7CC bottom: 0x00290000
Backtrace (may be wrong):
=>0x0040C229 in gta_sa.exe (+0xc229) (0x0028F804)
0x03A7E213 GetLoaderVersion+0x793 in modloader.asi (+0x1e213) (0x0028F81C)
0x03A83CCF GetLoaderVersion+0x624f in modloader.asi (+0x23ccf) (0x0028F868)
0x03A838C1 GetLoaderVersion+0x5e41 in modloader.asi (+0x238c1) (0x0028F874)
0x03A80E67 GetLoaderVersion+0x33e7 in modloader.asi (+0x20e67) (0x0028F890)
0x03A802C3 GetLoaderVersion+0x2843 in modloader.asi (+0x202c3) (0x0028F98C)
0x0053ECC2 in gta_sa.exe (+0x13ecc2) (0x0028F994)
0x00619B71 in gta_sa.exe (+0x219b71) (0x0028F9A8)
0x00748DA0 in gta_sa.exe (+0x348da0) (0x0028FA48)
0x03A82A14 GetLoaderVersion+0x4f94 in modloader.asi (+0x22a14) (0x0028FA68)
0x03A7DFF9 GetLoaderVersion+0x579 in modloader.asi (+0x1dff9) (0x0028FAA0)
0x03A83D70 GetLoaderVersion+0x62f0 in modloader.asi (+0x23d70) (0x0028FAF8)
0x03A8384A GetLoaderVersion+0x5dca in modloader.asi (+0x2384a) (0x0028FB10)
0x03A80DF1 GetLoaderVersion+0x3371 in modloader.asi (+0x20df1) (0x0028FB3C)
0x03A804FC GetLoaderVersion+0x2a7c in modloader.asi (+0x204fc) (0x0028FC54)
0x03A7F8A6 GetLoaderVersion+0x1e26 in modloader.asi (+0x1f8a6) (0x0028FC64)
0x03A7E102 GetLoaderVersion+0x682 in modloader.asi (+0x1e102) (0x0028FC9C)
0x03A83D70 GetLoaderVersion+0x62f0 in modloader.asi (+0x23d70) (0x0028FCF4)
0x03A8384A GetLoaderVersion+0x5dca in modloader.asi (+0x2384a) (0x0028FD0C)
Shutting down Mod Loader...
Shutting down menu...
Mod Loader has been shutdown.
- fastman.log:
- Starting fastman92 limit adjuster 4.3 for WIN_X86, compilation time: Jun 19 2017 19:00:46
Please visit http://fastman92.com
Solution platform: WIN_X86
Game detected: GTA SA 1.0 HOODLUM 14383616 bytes
Modified count of killable model IDs: 12600
Error reporting going to be applied.
GTA_ERROR_ATTEMPT_TO_LOAD_OBJECT_INSTANCE_WITH_UNDEFINED_ID enabled.
GTA_ERROR_MODEL_DOES_NOT_HAVE_COLLISION_LOADED enabled.
GTA_ERROR_CAR_GENERATOR_WITH_INVALID_MODEL_ID_IS_GETTING_REGISTERED enabled.
GTA_ERROR_IMG_ARCHIVE_NEEDS_REBUILDING enabled.
GTA_ERROR_STREAM_HANDLES_LIMIT_EXCEEDED enabled.
Error reporting is applied now.
Number of memory changes made: 32
- ViniZ0ZMensagens Nível 5
- Título : Vinicius
- Cyndaquill!Mensagens Nível 3
Desde : 28/10/2017
Deve ser modelos, vc usa modloader? Engraçado, é quase o mesmo erro q acontece com o Geneilson...
- MAU PC (mau msm):
Processador: Intel Pentium Dual 2.20GHz
RAM: 2GB
Placa de vídeo: nn sei só sei q eh onboard do pc msm
OS: WIndows 7 Ultimate 32bits
